hognit09
- Mar 7, 2010
- beaver dam, wi.
- 2016 viper ltx le,2016 viper ltx dx
Doing the airbox mod and wondering is there any benefit to bending the diverter? The diverter has a a slot to fit in On the shelf plate and if it’s not in there wouldn’t it vibrate ? My shelf plate also has this grove running through it so I sanded the diverter a little in hopes it won’t wear through and crack
Bend the diverter and either glue the shelf down or toss it.
hognit09
- Mar 7, 2010
- beaver dam, wi.
What should I adhere it down with ?
I used Permatex Ultrablack has lasted 2 seasons so far.What should I adhere it down with ?
Here 3 seasons no issues when glued.
https://ty4stroke.com/threads/airbox-mod-warning.133316/
https://ty4stroke.com/threads/7800m...-shaft-change-2017-shaft-bearing-info.141330/
Mills
- Dec 4, 2007
- Elk Mound, Wisconsin
- '14 Viper RTX, '06 Apex, '99 SX 600, '74 TL433F, '79 Trail Fire
Ah ha, that may be why I got a new load noise after the air box mod. I never adhered it down or remove the small ribs the plate used to fit into.
ateick
- Mar 11, 2019
- '24 Rene XRS 900R
'18 SR Viper RTX (SOLD)
'20 Poo XCR 850 (SOLD)
My shelf had white dust on it at 500km when I opened it. Couldn't handle the thought of it possibly continuing and going in carbs. Shelf was removed and diverter heated and bent.
hognit09
- Mar 7, 2010
- beaver dam, wi.
Wow! I cracked two of them in a row before gluing.Mine actually has a groove worn in shelf, that extends from slot that holds divider in
hognit09
- Mar 7, 2010
- beaver dam, wi.
Haven’t decided if I should buy a new shelf or lay some of that black ultra down that groove. Might also put some of the black ultra were the bent divider meets with shelf
I glued the whole divider in. That prevents it from vibrating. I wouldnt put it on the groove. Just get a new divider and glue it in or leave it out. Too risky to have that glue come off and go in motor.
Here
rb2001srx700
Does the air box mod actually help? New to the SR Viper and looking/reading a lot. Just trying to separate fact and fiction. Thanks Guys.
ateick
- Mar 11, 2019
- '24 Rene XRS 900R
Its the sum of a few things that works. Airbox, can and clutching. Can doesn't have to be loud or anything it will just flow better and save some weight. Clutch kit will get you softer engagement and a bit better top speed.
Yup allow more opportunities to see better top end since takes less time to get there.
