eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
Give it 3 ugga dugga's....... Problem solved
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
Note guys , not too much grease or never sieze , it will find its way out to the clutchs !!! been There !
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
OMG
How much did you use?
Kevin
Is this going to be an issues with the 2021 sleds or did they start machining the shaft properly?
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
2021 the shaft and bearing fittement has been addressedIs this going to be an issues with the 2021 sleds or did they start machining the shaft properly?
FrozenTows4
- Nov 6, 2014
- Brainerd Minnesota
- 2014 XF7000 Sold
2017 ZR6000RS
2018 ZR6000 El Tigre
- YOUTUBE
- FrozenTows1
Are you Sure? I bet it's still not locked. Shaft expander would be great for peace of mind. Rather than finding out later.2021 the shaft and bearing fittement has been addressed
Even at room temperature, a new bearing is pretty stiff turning. I'm locking mine down and be done for the next 10,000 miles.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Yes it was mentioned on a live Q and A with Jarrett from yamaha Corp.Are you Sure? I bet it's still not locked. Shaft expander would be great for peace of mind. Rather than finding out later.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
I wouldn’t bet the farm on that, time will tell
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
The last shaft I ordered beleive i end up with a updated shaftAre you Sure? I bet it's still not locked. Shaft expander would be great for peace of mind. Rather than finding out later.
This shaft was .0015" oversized and required to warm bearing and cool shaft to install
cjr
- Jan 28, 2018
- Old Forge
- 2018 Sidewinder 2021 sidewinder xtx le 146
Anything more on 2021 sleds having new shaft and bearing
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
No sight glass in chaincase! It's a grub screws to check levelAnything more on 2021 sleds having new shaft and bearing
cjr
- Jan 28, 2018
- Old Forge
Thanks Marc I noticed th sight glass just wondering if the 2021 needs wedgeNo sight glass in chaincase! It's a grub screws to check level
Turboflash
- Mar 18, 2019
- Southern MN
The question is have all old shafts been purged from supply line such that every 2021 got the new shaft?The last shaft I ordered beleive i end up with a updated shaft View attachment 156978 View attachment 156979
(BTW- bearings haven't changed. Still using 6009 which have an ID of 45mm = 1.77165").
cjr
- Jan 28, 2018
- Old Forge
I was referring to new sleds not replacement shaft
Turboflash
- Mar 18, 2019
- Southern MN
Yes, 2021. But still have ALL old design shafts been purged such that there was no way for a 2021 to have an old one?
- 51K
- 33K
