Psycho Dave
- Jan 8, 2013
- Norderåsen
- Sweden
- 2021 Arctic Cat Riot X
1986 Aktiv Karibo
I don't know if this has been posted before, but here is a video showing a Arctic Cat Alpha One that has belt temperature displayed in the display.
Start at 4:24
So now the question is, how is it done and how can we mount it and get it flashed in our displays.
Start at 4:24
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
Thumb warmer temp also?
Nice shop
Nice shop
Mototown
That would be good to know so you could back off the throttle on big tunes , but they should have just come up with more ventilation to the belt all the time
That seems very generic and I dont see a lot of value in that. In order to be useful we would need some sort of monitoring and reporting to be able to trend belt temp and when if the belt blew or had an issue. This would help to under stand ambient temp, ave temp, high/low temp etc. I have added a great deal of ventilation this year hoping it helps to keep everything under wraps running cooler.
Mototown
With alittle more stability in the single rail , that thing would gobble bumps on trails ... only draw back would be hard flat corners
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Great idea,wish my sled had that!
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Wouldn't work on a Sidewinder, first blown belt and its gone along with the guard and panels. LOL!
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
and that sensor looks like it would pick up under hood heat before any belt heat being that far away. Seems odd.Wouldn't work on a Sidewinder, first blown belt and its gone along with the guard and panels. LOL!
I do like seeing the multi-step thumb and hand heaters on the gauges for '19...like doos have.
Dan
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
SNOGOER 2019 Sled of the Year right there boys!
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
Dan
That looks like a directional sensor that would only look down at the belt.
Maybe Allen knows more.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Never seen one. Interesting, sure would make more sense then getting all that ambient underhood heatThat looks like a directional sensor that would only look down at the belt.
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
We've used some in the elevator trade & they were pretty accurate.
Even if it wasn't accurate, you may be able to see a trend or even "hotter then normal" that could help save a belt.
This could aid in tuning. I wouldn't have to take my panel off every stop to check with my Fluke Temp Gun.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
It's a thermistor and the belt will blow direct heat on it. These are pretty accurate. But who's going to be watching the gauge when they are pouring the power to it and looking at the next corner.
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
Mountain guys put extreme pressure & loads on their belts because they are running wide open under load the whole time. Even with clutches perfectly tuned they blow a LOT of belts.
They may be able to glance at it & say "it's time to whoa up for a minute Dude". ...... Cuz that's how they talk.
BTW: Mountain guys don't have corners.
