ATV PRO #11
- Jan 22, 2011
- Garson, MB, CANADA
- 2014 Yamaha Phazer XTX
Thought I'd share my pivot arm fix from yesterday. My stock was updated before I bought sled in 10. The one beside the skid is my spare I bought last season ( nov 2013 8gc-47332-02-00 )and broke within 200kms. Changed it out and was injured for the rest of season last year. You can clearly see how clean it is and paints not even worn away from bolting in or anything. Lol. Was sold on it being the "updated one" off the 14's but clearly was not as it is not the same as the one on my new 14. Shady.
I'll also include a photo of my 14 xtx's arm. You can clearly see the two prongs the shock bolt to is 1/8" thick, not the updated double sandwiched together ones. Also, notice the gusset across the arm on the 14.
So, not being a pro welder, here's my fix. Both arms are fixed the same. I now have a back up.
My settings were comp 9 rebound 15. Sag on hard. Strap #5 (full ski pressure). Shocks revalved by Jim 2013.
I've relieved the strap to #2 and recommendEd to my buddy to buy new carbides. I believe those settings put to much on the arm hence the continual breakage over the last season n half of riding.
See how it holds up for its new owner.
Test fit
Last seasons arm
I used 1" channel and slid up beyond the gussets and welded all points of contact. Then I used a smaller piece and ran it across the shock mount and welded all those contact points. Testing on sled chassis and moving in all positions with no binding anywhere.
Test fit
Last seasons arm
ATV PRO #11
- Jan 22, 2011
RAMSOMAIR
Don't forget to tighten the bolt going through the pivot bracket in the test fit photo!
ATV PRO #11
- Jan 22, 2011
ATV PRO #11
- Jan 22, 2011
Just did a search. And the 2014 xtx pivot arm 1's product code is now:
8GN-47331-03-00
Why would in change from 8GC to 8GN??
I understand the updates 8xx-xxxxx-01(02 or 03)-00
8GN-47331-03-00
- 113K
