stgdz
- Mar 27, 2021
- Buffalo MN
So last year I picked up a set of used ca skis. They aren't the razors or the xpt's but an older less aggressive and came with a set of four inch carbides.
Typically I run 8 or 10" carbides due to my stud qty and I figured I would need a longer set after taking it out but to my surprise the push that was so inherent was virtually gone and I could rail around the corners with ease.
With that being said my plan was to get triple (6 maybe 8in) points for this season but based on the ski profile this has I'm starting to question that and stay with either a round bar that's either 6 or 8in.
Looking at the bottom profile there is a taper at the end of the ski on the left and the keel extends a bit longer? Will I ruin my handling by going to 8".
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
That looks like an xpt to me. And I would run 8-1” all day long. Take longer to wear out as it’s spread out in more surface area too. Aslong as your arms are up for it I go as I can.So last year I picked up a set of used ca skis. They aren't the razors or the xpt's but an older less aggressive and came with a set of four inch carbides.
I personally run 10” shapers on c&a xcs on front of my sidewinder
