RealDeal
It's my brothers sled, looked in tech book know what code means , can't figure out whats wrong, checked out all relays, disconnected boondocker system and power commander, still no start. Fuel pump runs and it turns over but no start. Any ideas let me know.
Choids454
Code 43
I threw a code 43 on my 09 Nytro RTX with a Powderlites kit. Found that I blew a fuse on the left side of the sled just infront of the battery. Changed the fuse and put electrical greese on both fuses as well as the relay. Started right up. Hope this helps and you get it running.
YamYboY
Fuel system voltage (monitor voltage)
Power supply to the fuel injectors and fuel pump is not normal
This is what the service manual says about error 43
RealDeal
looking at sled now and fuel pump makes clicking noise and flash's 310 then 320 then 43, replaced all relays and no go
RealDeal
Brother just got back from dealer, voltage regulater went bad and took out 1 injector and the fuel pump, good thing for warranty.
