TheKoning
After about an hour of hardish riding in deep stuff, my coolant bottle keeps filling up and leaking out of the overflow hose. Why is this happening? My dealer doesn't know why.
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
Have you overheated recently? Usually head gasket when this happens, or a warped head if it got really hot. The engine combustion leaks past the gasket and pressurizes the coolant system, pushing it out the overflow.
maxdlx
Watch for bubbles in coolant resivior. How much collar is it pushing out.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
Sounds like a head gasket and possibly warped head. I've done a few of these on the Nytro motor with the same symptoms. If your dealer can't diagnose a bad head gasket you need to find someone new.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
X2Sounds like a head gasket and possibly warped head. I've done a few of these on the Nytro motor with the same symptoms. If your dealer can't diagnose a bad head gasket you need to find someone new.
