micheal_654
How do I bleed the air out of the cooling system? I tipped my nytro over and all the coolant ran out of the reservoir. Thanks in advance
arteeex
You only need to bleed air from the coolant system on the MTX with the under-tunnel heat exchanger. For the MTX there’s a bleed valve on the rear of the heat exchanger.
Take of the radiator cap and top it off - give it few minutes before you put the cap back on, and then fill the reservoir to the cold level mark. You could see some over flow on the first run, but that's not a problem unless it all dumps out. After running it a while add more to the reservoir to bring it up to the hot fill mark.
