Sled Dog
You have another order for two sets of 4.
Frozenstiff
- Dec 24, 2009
- Prescott, Ontario
- 2013 Arctic Cat Turbo
Great pricing. I got mine on order. I,m sure these will be selling out fast.
crazyyamaha
Just ordered a set anything has to be better than stock ones.
The ones you have in stock now are brass correct? What grade of copper are you going to be using and have they been tested? I'm sure you guys know I have them also and they are the correct blend of copper and have been tested alot and are made here. Copper is extremely expensive so if you can get them made over seas and land them here and make some profit for 15 dollars that's insane. I'd be checking on the blend of material.
upei93
- Apr 27, 2008
- Dalhousie, NB
2009 Nytro XTX
Crewchief47 said:Pre-order page is up: Exhaust Donut
I hope to have these by the end of April or sooner if I'm lucky. These will work on all 3 and 4 cylinder 4 stroke Yamahas except for the 2011 Apex with EXUP. NO installation instructions are included with these either.
There are some helpful threads here on TY though:
RockerDan Thread for APEX
Grizztracks Thread for RS/RX
Another NB order...
Sled Dog
thistle said:The ones you have in stock now are brass correct? What grade of copper are you going to be using and have they been tested? I'm sure you guys know I have them also and they are the correct blend of copper and have been tested alot and are made here. Copper is extremely expensive so if you can get them made over seas and land them here and make some profit for 15 dollars that's insane. I'd be checking on the blend of material.
100% copper is 100% copper its the labour its very cheap in China I think the brass may very well do just fine in this application as well time will tell. The melting points of brass or copper are only 160 C apart.
Elements Symbol Melting Point Celsius Melting Point Fahrenheit
Aluminum Al 659 1218
Brass (85 Cu 15 Zn) Cu+Zn 900-940 1652-1724
Bronze (90 Cu 10 Sn) Cu+Sn 850-1000 1562-832
Cast Iron C+Si+Mn+Fe 1260 2300
Carbon C 3600 6512
Chromium Cr 1615 3034
Copper Cu 1083 1981
Gold Au 1063 1946
Hydrogen H -259 -434.2
Inconel Ni+Cr+Fe 1393 2540
Iron Fe 1530 2786
Lead Pb 327 621
Magnesium Mg 670 1240
Manganese Mn 1260 2300
Monel Ni+Cu+Si 1301 2400
Nickel Ni 1452 2646
Phosphorous P 44 111
Silicon Si 1420 2588
Silver Ag 961 1762
Stainless Steel Cr+Ni+Mn+C 1363 2550
Steel-High Carbon Cr+Ni+Mn+C 1353 2500
Medium Carbon Cr+Ni+Mn+C 1427 2600
Low Carbon Cr+Ni+Mn+C 1464 2700
Tin Sn 232 450
Titanium Ti 1795 3263
Tungsten W 3000 5432
Zinc Zn 419 786
crazy canuck
One set pre-ordered.
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
Because it's a pre-order at the $13 price. The gaskets should be in by the end of April. They will be $15 each after April 30th or when the pre-order sells out. If they sell out before I get them, the page will say 'notify me' instead of 'add to cart'.
Kaz
Why won't these work on the new 2011 sleds with EXUP?
Super Sled
- Feb 25, 2009
- Summit X
Copper donuts are the way to go. Real 100% copper. Not the copper blend "updated" ones yamaha wants to sell you.
It's awesome to see
Crewchief, thistle, and other TY site supporters providing us with options and products we Yamaha owners
Can use that will help us. Replacing donuts is a
Lame, tedious task and hopefully copper donuts are the Answer to never having to replace the donuts again!
It's awesome to see
Crewchief47
- Jan 16, 2006
Kaz said:Why won't these work on the new 2011 sleds with EXUP?
I'm not 100% sure they won't but I haven't purchased one of those donuts yet to check it out. The 2011 Apex now shares an OEM donut part number with the Phazers.......Yamaha obviously did something different enough to give them a seperate #, but it could just be material composition.
Super Sled
- Feb 25, 2009
- Summit X
Maybe by year2011 Yamaha actually made a
Donuts that will last....
Snowmobileaddict
Just placed my order
Can't wait to finally make this upgrade
kinger
I dont understand the difference between crewchief and thistle and the $15 to $35 price difference?
I need a set for my SC apex, the exhaust is getting a makeover and I want to not mess with it again.
Sled Dog
kinger said:I dont understand the difference between crewchief and thistle and the $15 to $35 price difference?
One is made in Canada (thistle) The other is made in China. The difference is Labour cost.
