2BLUE4U
My dealer gave me CR9EK plugs for my Attak...The plugs I took out are CR9EKB and have a solid terminal vs. a screw-on type on the CR9EK. I also have a fuel controller that was set-up with the plugs that re in it now (CR9EKB) Is this going to make a difference? Need HELP please
chevmal67
you need the cr9ekB. I just went through this on accident tonight actually.. $27 oops. It ran with the cr9ek but the terminal is not making a good connection in the coil. you will need the solid to make a good connection. You can tell if you have the coil out and just try put the plug into the socket. I could not feel the 9ek's when putting in the socket. then i tried with the 9ekb's and it has a defininate "snap" into the socket.
