BIG BLUE 2
- Dec 27, 2013
- 2011 FX NYTRO XTX
What the best/safest way to remove a decal on a plastic body panel without damaging the plastic?
I used a heat gun with great results
I have done this multiple times. Hair dryer ( just a little heat to get the glue soft ) and start picking at it. Comes off pretty easy once you get going. Some stickers on the tunnel are a b**ch but everything comes off. Use a standard cleaner to get any left over glue.
Tyloooor
x2 on heat gun- then use "goo gone" to get the left over glue off
Nytro40th
- Sep 19, 2007
- Amherstview Ontario
- 2014 SR Viper RTX SE
Rubbing alcohol and a heat gun, or a hair dryer
dab102999
Tyloooor said:x2 on heat gun- then use "goo gone" to get the left over glue off
x2...goo gone is gooood stuff
Dr. FeeLGooD
Heat, goo gone and an old credit card or plastic hotel room card. Metal scraper may damage your plastic.
porkchop
Hair dryer on warm (too much heat from heat gun could warp plastic), peel easy & spray with WD-40.
Works for me.
Have used straight gas to clean adhesive off as well.
Works for me.
BIG BLUE 2
- Dec 27, 2013
- 2011 FX NYTRO XTX
Thanks for the advice guys. I will be borrowing the wife's air dryer as soon as I get a few minutes.
toyota4runner
Don't use wd-40 on the hood. It will ruin the finish. Side panels not so much but hood and gas tank cover are sensitive for some reason. Isopropyl alcohol or goo gone works much better
- 11K
