fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
had issue where the isc error code is up and it's idling really high now. Has anyone had this as an actual issue or only just a fuel treatment issue that solves it every time? Has anyone had the isc apart and found that a lube or cleaner would fix it? Just left house for the day but thought I would get some solutions for when I get home ty
herndonp
37 is fault code for ISC. Go here and read instructions and run diagnostics at bottom of post for code 54 ISC test and it should vibrate. http://www.ty4stroke.com/threads/fault-codes-relay-fuse-location-wire-diagram-diagnostics.83992/
Pete
Pete
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Done tests. That's what was screwing up my power commander it was just flakey at that time. Now getting code. All I've read or found on it was it gets kinda loaded up and injector cleaner and a hard ride cleans them out. Hoping that's the case but didn't know if anyone's had one actually go bad before or if they have disassembled and cleaned them successfully without running sled for a tank or 2
herndonp
I would try some (Yamaha Engine Med Rx ) or Seafoam as that would be the safest approach and least costly. I did find a guy who cleaned a Yamaha Zuma (scooter) throttle body and ISC and even he mentioned if your not careful it will cost you a complete throttle body assembly as the parts are not sold for the ISC. Here is a link to what he did for reference http://www.zumaforums.net/phpBB3/viewtopic.php?f=57&t=23025
Pete
Pete
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Awesome thanks!
