My 06 Attak exaust is stuck. Tried to push with screw driver on the clam . Hit the can with hammer on a piece of 2x4 centered.
The pipe is so tight to pipes I can't get it off..
Suggestions. Thanks.
Make sure the front bolts for the mid pipes are tight and dont remove the clamp and or donuts on the flex joints. Remove clamps as you have show in picture, remove bolts that hold down the can and then you have to pry it back and forth side to side as you are pulling back.. it will come off. Lots of swearing.. but it will come off.
Ok, I'll try it. Damm thing is ON there.
If you can get someone to tap on it with a big #*$&@ rubber mallet as you are pulling back and rockin it.. it will come.
DJ Hennessy
- Jan 30, 2016
- Barrie, ON
- 2016 Yamaha Viper RTX SE
2006 Yamaha Apex RTX
what Mr.Sled said, plus mine were super tight as well, I shot some WD-40 on the gaskets and lit the muffler section up with a torch a bit. Side to side wiggling and pulling does the trick!
slowride06er
tomanytoyz
Heavy duty air hammer (Just like an Impact) with a flat bit and some wood or some hard plastic . Some heat sometimes if ya need it ,and it will move .
