SchelT
Technical question needing answered. Standard front shock length on a Nytro XTX is 17.5"
New Fox QS3 is 18.5"... a full inch longer. Rumors say a longer front shock is a change for the better on the Nytro front suspension..Thoughts?
XTX Chris
- Feb 2, 2014
- Carnarvon Ontario
- 2009 FX Nytro XTX
2015 Viper LTX DX
Actually for trail handling shorter is better...star suspension will lower your front shocks by an inch I think, or recommends JRE spindles or SLP spindles for the same effect. JRE recommends a longer shock by 1 inch with their spindle to get back to stock clearance. Off trail though you want all the clearance you can get.
Sent from my iPad using Tapatalk
m.schuey7
- Feb 4, 2014
- Colorado Springs, CO.
- 2011 Yamaha Nytro XTX
Lengthening the front shock on my XTX was a great improvement in ride quality and in chassis control (able to use lower pressures and still maintain shock travel) It seems that the higher I keep the nose on my XTX the better the chassis performs. I'm using Fox Evol 18.25" length that I bought used from a Guy with a Ski-Doo Sno Cross race sled.
SchelT
I see that you changed the front spindles. Would that be a necessity if I were to go with the taller shocks?Lengthening the front shock on my XTX was a great improvement in ride quality and in chassis control (able to use lower pressures and still maintain shock travel) It seems that the higher I keep the nose on my XTX the better the chassis performs. I'm using Fox Evol 18.25" length that I bought used from a Guy with a Ski-Doo Sno Cross race sled.
MNBlizzard
I ran the EVOL R 17.5" shocks and they were wonderful. Hands down the best ride I've had and the adjustability with the air pump was great. Soft for off trail and harder for on trail and lessen the body rolling.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
I would give them a try. You can always back off preload to drop nose a bit. I have jre spindles with longer shocks. Spindles helped handling a bunch. Flatter more stable. Then changed from the playschool fox floats to axis coilovers at the longer length and it was much better smoother over bumps smoother transitions from side to side and initiating corners aswell as no harshness on studder bumps
m.schuey7
- Feb 4, 2014
You could use either Stock or JRE spindle with longer shocks, like the earlier post stated you can adjust ride height with fox so you have the opportunity to play around with your setup and dial in what works for you. The JRE spindle as mentioned above cures other issues.
stubb111
FYI....the 09' xtx did come with 18.25" shocks stock, so I think it would make a big deal. I run a skinz front end with 18.25" fox float x evols (race take offs) and skinz states the front end designed for 17.5" shocks. I simply run more sag on the front shocks to get the front end where I want it to be. I measured where it liked it setup before I swapped it out and adjusted it the same after new front end. the shocks have enough adjustability to make up for shorter stroke. no worries just run less spring tension on shocks.
