Matthew
Ok so I have been skimming through pages and I see a lot of people say to use regular gas in the 03 rx1 (not preamuim?) and they use sinthetic in the sled (dealer said not to use it due to the ring problem?) anyone can fill me in thanks
I always use premium on my sleds... that ethanol separates and plugs up the pilots.
Dalooch
- Feb 14, 2015
- Rx1
Speaking from my experience yes run only 87 octane. My sled from day one rode it for the most part wot where the wife's had more break in period. They both use a little oil from my experience so I'm to believe break in had nothing to do with it. I've run both non syn and synthetic oil and really can't tell if it makes any difference. Oil consumption has been as high a a qt every 300 miles. I feel the consumption is blow by the rings due to carbon. To prevent usage I throw a third of a can of sea foam in the tank every other fill up and that really does the job on usage. Back pipes now are all carboned up from doing so. I'm going on 10 k miles have the airbox mod jets and clutched and it still pulls like a freight train when I hammer it.
Whats the reason behind 87??
Dalooch
- Feb 14, 2015
- Rx1
If I recall the manufacture says use 87 and also recall this with my Vstar. Totally agree with you today gas with ethanol is garbage and has no shelf life. When I ivestigated back when I was shocked to here 87 burned actually hotter then 91 octane by about 10k btu's.
Correct it does burn hotter that's for sure but with the problems with the ethanol to me it's not worth it.
Matthew
So premium gas and oil is up to the user thabks guys
straycat03rx1
- Aug 6, 2014
- t cats out the a$$ one rx1
Sleds owners manual calls for regular gas. Whats the ??
Dalooch
- Feb 14, 2015
- Rx1
Really no verdict on what type of gas to use. Pros on using regular your saving a little bit of money at the pump. Cons you let that gas sit and you'll be real fimaliar on cleaning the carbs. And vise versa on premium fuel. No profromance upgrade by doing so I'm thinking.
If using the sled regularly 87 is fine. We always run 91 for the last few tanks with seafoam and have not had any problems. As to the oil, owners choice. Some of the 03 sleds burned synthetic worse than regular, others it was the other way around. Only way to tell was to try it.
sledheadgeorge
X2
YammyRX1
Sled is tuned for 87 so unless you are really worried about ethanol just go with it and use the premium for storage. I think oil consumption varies more with driving style than oil type, the more throttle you use the more oil you use. Most guys are trying synthetic for better cold starting.
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
I ran 87 in my Warrior for 18,000 miles but filled up with premium for its summer sleep. Motor is designed to run 87. What you run is your choice! As far as Synthetic oil goes if you burn oil like its gas then I'd do a rethink on expensive Synthetic oil. If your consumption is low then why not. It is a better oil!
Vectornut
Are some of you saying that premium doesn't have ethanol? We have it in regular as well as Premium in our area at 10%. We can't buy premium without ethanol.
Then dont bother getting it... stick with lower octane if it has ethanol.
