Nytrosnox
- Aug 1, 2009
- Cleveland, WI
- 2013 Nytro XTX 2017 Sidewinder XTX
Anyone find a good safe Gopro mount for front bumper on a Nytro?
Cubby
- Dec 14, 2009
- South of Winnipeg, Manitoba CANADA
- 2015 Ski Doo 900 ACE Renegade Adrenaline
2007 Yamaha Phazer GT
I use RAM mounts - the Handlebar mount and the Gopro adapter:
http://www.rammount.com/CatalogResu...45049052057090045071079080049085/Default.aspx
Nytrosnox
- Aug 1, 2009
- Cleveland, WI
Looks good does it hold its position when off trail?I use RAM mounts - the Handlebar mount and the Gopro adapter:
Cubby
- Dec 14, 2009
Yes - very well. Its all aluminum and I use them for everything from holding the GPS on the sled, cameras, GPS in the car, camera on my bow, bike etc.
I have also mounted it to the ski loop facing back to film carving.
They are by far the most versatile and robust.
Nytrosnox
- Aug 1, 2009
- Cleveland, WI
Wow thanks I will be trying out that. ThanksYes - very well. Its all aluminum and I use them for everything from holding the GPS on the sled, cameras, GPS in the car, camera on my bow, bike etc.
superfan75
I have a RAM mount on the GPS on my road bike and it great. It holds it's position without moving, yet it has rubber in the knuckle to absorb vibrations. I bet it would work great for your GoPro to. I'd like a GoPro someday, the footage you can shoot with those cameras is amazing.
Snakebit
Ram mounts are the balls. That's what I used to mount the Vector speedo on my Nytro. If I am doing a lot of standup, I give the speedo a tilt up so I can get a good look see at it, tilt it back down for cruising.
Nytrosnox
- Aug 1, 2009
- Cleveland, WI
Just got a couple loRam mounts are the balls. That's what I used to mount the Vector speedo on my Nytro. If I am doing a lot of standup, I give the speedo a tilt up so I can get a good look see at it, tilt it back down for cruising.
Just got a couple looks good. Does anyone know were to get any longer mounts. I see some of the mountain guys using off the rear bumper or in their backpacks?Ram mounts are the balls. That's what I used to mount the Vector speedo on my Nytro. If I am doing a lot of standup, I give the speedo a tilt up so I can get a good look see at it, tilt it back down for cruising.
Cubby
- Dec 14, 2009
You can get a double ball arm so you can join 2 mounts together:
http://www.gpscity.ca/ram-mount-1.75-inch-long-double-1-inch-ball-arm.html
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
I use a pole mount with my go Pro that is made from an extendable snow scraper. One end has a Ram ball the other has the 3 prong Go Pro mount in it. I have used it all over the place and all over the sled including on a backpack and on either bumper.
Oh and when I don't want to use it it fits under the hood strapped to my spare belt.
