DoktorC
Any thoughts on using JB weld to help seal a small leak I have on my front heat exchanger?
I just bought an 05 RX and it seems that it took a good hit to the belly. The outside of the exchanger is fine but there is a small drip on the inside around the hose inlet. I'm not sure there is an easy way to fix this but I don't really want to disassemble the whole sled to get a welder in there....
BLUEDOG
repair
I had the same problem with my 06 APEX, what a pain to pull the left side heat exchanger, had a local shop re-weld/aluminum and then pressure test, found another crack and they fixed that, reassembly and purchasing the proper rivets was almost as much of a pain, in the end it was a lot cheaper than buying the replacement exchanger, I would have had to go through the labor either way! You just need to find a shop fimilar with aluminum repair....
Dog
Dog
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
DR C I used JB weld on a front heat exchager yrs ago, sled now has over 10,000 miles and never a problem, we cleaned and slightly roughed up the surface as prep. I would do it again in a minute
Good luck
Yamadoo
Good luck
Yamadoo
DoktorC
That's what I wanted to hear....I figured it wouldn't be a problem but I wanted to hear from someone who has done it.
Thanks.
Thanks.
