Is my subframe bent?
Jeffz
Cresco, Iowa
2008 Yamaha Nytro RTX 40th
2007 Phazer "RTX"
Had the front end off to make some steering block bushings (Upbushman style) and noticed a bend in the square tubing at the bottom of the subframe. This isn't supposed to be here is it?
not sure. did you hold a striaght edge on it? or is it supposed to be a bit of a degree angled up?
how does the bottom or sides look? any cracking or paint come off?
i guess you'll see once you put it back together, if it takes some "finess" to get in place.
It's definitely not straight. It has a slight upward bend towards the back. Everything seems to line up when its on the sled and there is no cracked paint or anything.
maybe your ok. i'd go to a dealer & see if they have a phaz & ask to look at it.
my sled is 4hrs away or i'd look at mine.
i'll take a look at the phazers at the upcoming show in milwaukee and see if i find anything.
yeah it's bent alright, just looked at my sled and it's not like that.
Any pics of your sled there XT-GT ????
No fear, that's the way they come from the factory.
I'll post up some pics of a new one for you to compare..
Excellent. If the holes didn't line up when when it's installed, I might be a little worried.
I have to take the a-arms off, then get the M10 out of the SX and get that ready for powdercoat and installation in the Phazer.
RoicIND is correct, this is how they come. I looked at my new subframe that is still in the box and it has the same bend.
sure do.
i have a thread for my build up a few pages back.
post is thanks OFT racing.
i don't want to highjack jeffs thread here.
