FAMILYMAN
We're has everyone tie into power?
Any pointers, starting install this week.
wot-75
FAMILYMAN said:We're has everyone tie into power?
http://www.kosonorthamerica.com/instruc ... 029001.pdf
Instructions look like you should tap into switched power coming off the ignition switch..
I would send it back and get a normal boost and AFR guage from someplace else... this things is junk. I have been trying to get it to read right without errors on my sled and Yamaha Tims... something is just not right with it... install at your own risk...
loudelectronics
I have the autometer boost gauge and it is junk too. Never starts off at 0. It is either at vacuum or boosting at idle depending on where I am at. I always have to zero it before I ride.
FAMILYMAN
Thanks for all the positive remarks....
Ebay it, not sure if it's returnable.
tmk50
I have the Koso boost only guage on my nytro and it has worked great.
Some info on the one you bought on this thread - but not much about the install itself
http://www.snowest.com/forum/showthread.php?t=366674
Yamadog
I have The AEM on mine and it works great and easy install the best power is the heated shield plug in the right foot well by the revers actuator.
I mounted them behind the gauge pod under the windshield and when I take power away I can run stealth and noone knows its a turbo
tator
Yamadog said:when I take power away I can run stealth and noone knows its a turbo
like you do with half of your dash?
Yamadog
tator said:Yamadog said:when I take power away I can run stealth and noone knows its a turbo
Yup you have to pay extra for that
tator
Yamadog said:tator said:Yamadog said:when I take power away I can run stealth and noone knows its a turbo
you must have every add on possible!
Yamadog
I got everything you can except a co-pilot (still searching) oh and graphics are stock
Turbo
upgraded waste gate
upgraded fuel pump
turbo boost switch 6#'s and 9#'s
Carillo rods
Wiseco Low compression pistons
MPI Aero lightweight can (muffler)
AEM AFR Gauge
Demon Boost gauge
simmons skis
Evol RC2 shocks
handle bar bag
xtra large rear tunnel bag
Car horn to get slower sleds out of the way!!!!
150 stud points
4th wheel kit - not on yet
tunnel flares - not on yet
Polaris PRo R 800 for the days the Viper is broken
Turbo
upgraded waste gate
upgraded fuel pump
Carillo rods
AEM AFR Gauge
Demon Boost gauge
simmons skis
Evol RC2 shocks
handle bar bag
150 stud points
FAMILYMAN
Returned it. Innovate gauges ordered.
Yamadog
FAMILYMAN said:Returned it
What? Your sled or copilot?
Did not know you could return your sled or I may look into it!!!
