Mooserut
- Jan 5, 2016
- Gaspésie
- yamaha vkpro 2006, skandik wt 1998 500f
Did anyone of you ever experienced a little leak of coolant liquid on top of the carburator just under the coolant valve???
BACK COUNTRY YAMAHA
- Nov 26, 2015
- newfoundland
- 1997 vmax 600 sx, 99 venture 600, 2004 vk 540, 2006 Yamaha vk pro, 2009 venture multi purpose and 2006 venture 500 xl current ride 15 rs viking pro
Yep, I had one on my 06 pro, not a lot but never the less a leak. I took off the stainless top plate that has the two screws and pulled out the valve and cleaned up the o ring, inspected it and reinstalled with a little petroleum jelly, no more leak 15,000 kms later. has to be done cold of course! best of luck!
Mooserut
- Jan 5, 2016
- Gaspésie
thanks ....doesn't look to hard to do!!!!!!
Jim Bob21
- Oct 8, 2020
- Chelmsford, Ontario
- vk professional
great fix. mine just had a major leak. valve was very hard to turn. I think o ring was out of place. popped it apart, new o ring and lube. all good now... thanks for the fixYep, I had one on my 06 pro, not a lot but never the less a leak. I took off the stainless top plate that has the two screws and pulled out the valve and cleaned up the o ring, inspected it and reinstalled with a little petroleum jelly, no more leak 15,000 kms later. has to be done cold of course! best of luck!
