pro116
has anyone tried the mpi standalone fuel injection this past year?
tmk50
Is MPI's kit the same as Impulse - just a re-brandi? Is that accurate?
pro116
I believe so,on Mpi 's website it says that it can be used with impulse turbos too.
tjc
I have read a lot about the impulse set up. It sounds like it is not good on gas and it takes some tinkering to get right but after that it is good. Also I guess the newer closed loop v.2 is better also.
This is not first hand but just what I have seen on here and snowest.
MOUNTY
I thought the whole point behind the stand alone was there was no tinkering, plug and play? I am definately going to do some deep research into this before pulling the trigger at that price.
tjc
this is for the impulse but some good info
http://www.snowestonline.com/forum/show ... ht=impulse
MOUNTY
Some good info, but does not really answer my Q?
For those who are running an MPI Supercharger on a Nyto with GEMS CONTROLLER and have changed up to a stand alone from MPI, what are your thoughts, good and bad?
stephenpen
Anyone else have any input on this standalone. I'm thinking of using it on a FPP Nytro.
Not a big fan of the Gems
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
Any of you guys pick up the one for sale in the classifieds for $400 a month ago?
stephenpen
Why are they so cheap used ?
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
That is what i thought considering they are $$$$ new.
stephenpen
I could not pass it up.
Accentstripe1
Standalone
I run that standalone on my impulse nytro. Only tinkering I had to do was setting the fuel pressure to the right psi. I also run it with the O2 correction and the system works flawless.
A.Granath
- Sep 5, 2013
- Sundsvall, Sweden
- Sweden
- Yamaha Viper MTX 162" MCX Turbo 190
- Sundsvall
This year im replacing my gems for a mcx controller on my MPI 180 S/C nytro!
+3 injectos, able to logg data to your smartphone ect.
Parts will arrive here this week, i will put up some picures for you who are interested!
//Anders
//Anders
