V10nr'
- Nov 4, 2009
- Canton Michigan
- 09 Nytro XTX, 11 Polaris Rush, 04 Sabercat, 99 Polaris trail.
I have no speedo and the dash alternates between odometer and check engine. The engine idles fine but then when given gas is revs and then drops revs over and over.
Drive bearing??
Drive bearing??
is it flashing a code number also . could it be the T.O.R.S. activating
RIGIDONE
make sure your speed sensor bolt did not come out..
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Sounds like a short.
V10nr'
- Nov 4, 2009
- Canton Michigan
Some squealing from clutch side. Was able to drive sled but the odo and check engine kept alternating. No code. This all happened while I was riding. While riding I had no speedo.
canoehead
- Jan 14, 2011
- NE, Alberta
Have you blown a belt recently?
I would check the Speedo side bearing below the secondary clutch
poor farmer/logger
- Dec 3, 2012
- Saskatchewan
I've heard of those exact symptoms when the driveshaft bearing goes out. Simple to check it so I'd start there.
V10nr'
- Nov 4, 2009
- Canton Michigan
Yes and no. The belt was just starting to fall apart. But I rode 2 days after that with no problems.Have you blown a belt recently?
V10nr'
- Nov 4, 2009
- Canton Michigan
Ok sounds good. That is what I was thinking.I would check the Speedo side bearing below the secondary clutch
V10nr'
- Nov 4, 2009
- Canton Michigan
Will do and thanks for all the replies.I've heard of those exact symptoms when the driveshaft bearing goes out. Simple to check it so I'd start there.
V10nr'
- Nov 4, 2009
- Canton Michigan
It was a drive bearing and a bolt that broke off in the chain case and then knocked out the speedo sensor. Absolutely nothing left of drive bearing.
herndonp
How many miles on it?
V10nr'
- Nov 4, 2009
- Canton Michigan
5800 Miles. So people check those bearings.
poor farmer/logger
- Dec 3, 2012
- Saskatchewan
Lots grease them seasonally. Takes all of about 20 minutes half a hour to do. Cheap easy insurance. I think there might be a link on the nytro how to page.
