yam429
- Jan 18, 2009
- Saint Michael, MN
- 2009 Nytro XTX, 2010 Vector LTX, 1981 SRX 440, 1989 Inviter, 1991 Snosport, 2004 Snowhawk
- Saint Michael
Does anyone know if the Stator from a 2014 Nytro will work in a 2009 Nytro? I notice the part numbers are different but also heard that the 2014 Stators are better.
They really never changed them all that much. Not sure why it would matter.Does anyone know if the Stator from a 2014 Nytro will work in a 2009 Nytro? I notice the part numbers are different but also heard that the 2014 Stators are better.
Can you post the part numbers ?
Did you looked at the fiche online and see if the new number bow supersedes the old?
yam429
- Jan 18, 2009
- Saint Michael, MN
- Saint Michael
yam429
- Jan 18, 2009
- Saint Michael, MN
- Saint Michael
Maybe the plug is different?
RobX-1
- Coldwater, OH
It appears starting in 2012, not 2014, they switched from the 8GL-81410-00-00 and started using the 8HU-81410-00-00
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
The rectifier/regulator hasn't changed so the stator's connection to it hasn't changed either. The rotor (fly wheel) part number changed with the newer stator so if you went with the newer part number you might need to replace the rotor with it.
Rick's Motorsport Electrics have decent stators at a better price than OEM. https://ricksmotorsportelectrics.com/New-OEM-Style-Yamaha-Snow-Stator-24_402
yam429
- Jan 18, 2009
- Saint Michael, MN
- Saint Michael
Ok thanks. Just gonna stick with the ‘09 part number then.
Gone Blue
- Oct 11, 2006
- Howell, Michigan
Grizz, have you run one of Ricks stators?The rectifier/regulator hasn't changed so the stator's connection to it hasn't changed either. The rotor (fly wheel) part number changed with the newer stator so if you went with the newer part number you might need to replace the rotor with it.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
I've installed them for others (stators and starters). So far I've never had or known of any problems with them.
Gone Blue
- Oct 11, 2006
- Howell, Michigan
Thanks Grizz. I am anticipating needing a stator at some point with 10,500 miles on my 08'.I've installed them for others (stators and starters). So far I've never had or known of any problems with them.
