SchelT
Hello All!...
Has anyone installed the OFT tunnel plate on their XTX? How much time and or labor? I was thinking of ordering the plate for use with OEM muffler.
Nytro-glycerin
- Dec 13, 2014
- 2010 Nytro XTX Black edition
Just installed mine. Not bad, maybe 2 hours of work. Remove seat, plastics, heat shield, remove muffler, drill holes, rivet it on, reinstall. I got the OEM version and added aluminum on top and cut it out to fit my MBRP pipe. That way I can switch pipes easily still. OFT did a great job on the fit and finish.
Sent from my pocket computer so excuse my spelling
SchelT
Great info..Thank youJust installed mine. Not bad, maybe 2 hours of work. Remove seat, plastics, heat shield, remove muffler, drill holes, rivet it on, reinstall. I got the OEM version and added aluminum on top and cut it out to fit my MBRP pipe. That way I can switch pipes easily still. OFT did a great job on the fit and finish.
SchelT
Did you have any difficulty removing the stock muffler? Saving the exhaust seal?Just installed mine. Not bad, maybe 2 hours of work. Remove seat, plastics, heat shield, remove muffler, drill holes, rivet it on, reinstall. I got the OEM version and added aluminum on top and cut it out to fit my MBRP pipe. That way I can switch pipes easily still. OFT did a great job on the fit and finish.
Nytro-glycerin
- Dec 13, 2014
I had trouble simply removing it due to the crazy bond it had (never been apart since factory. I ever so slightly pried on the tabs to loosen it as much as I could, and then twisted the muffler off, since straight pulling didn't do anything. Just remove the muffler bolts by the tail light before you try and twist it lol. Take it easy on the header as much as you can in terms of being rough with it. My gasket came out relatively unscathed, not that I know what a new one looks like lol. I reused it, shouldn't be a problem. Time will tell!
tippmannator
Have u noticed a decrease in the ice build up?
Sent from my SCH-R530U using Tapatalk
tippmannator
Lol never mind.....I just saw u posted this a day ago....for some reason I thought this was an older thread
Nytro-glycerin
- Dec 13, 2014
I wish I could tell ya.. The snow situation isn't helping with that lol. I will post back once I go for a ride and let you know!
tippmannator
Same here.....not enough to ride.
Fasteddiee122
- Apr 11, 2015
- Websterville VT
- 09 yamaha nytro fx
sprintcat
Good job did you have 2 take off the tunnel protectors and exhaust?
Fasteddiee122
- Apr 11, 2015
- Websterville VT
Just had to drill out the back tunnel protector bracket rivets . Slid right up over the end of them into place and yeah I took the muffler off kinda went buy a picture of the oft one cut my hole little by little took me a couple hours and a few rivets .Good job did you have 2 take off the tunnel protectors and exhaust?
sprintcat
Looks like it will work have you had any snow yet on try it out? And what type of material did you use ?
Fasteddiee122
- Apr 11, 2015
- Websterville VT
No snow yet to try it , it's a piece of aluminum can't remember the thickness it's the same stuff most people use on race cars 0.35 maybe ?!?Look like it will work have you had an snow yet on try it out? And what type of material did you use ?
sprintcat
OK thanks
