- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Code 11: Cylinder identification sensor or circuit problem.
Code 12: Crankshaft sensor or circuit problem
Code 13: Intake pressure sensor or circuit problem on Cylinder #1.
Code 25: Intake pressure sensor or circuit problem on Cylinder #2.
Code 14: Intake pressure sensor hose problem. Hose is detached, loose, plugged, pinched, etc on Cylinder #1.
Code 26: Intake pressure sensor hose problem. Hose is detached, loose, plugged, pinched, etc on Cylinder #2.
Code 15: Throttle position sensor or circuit problem.
Code 16: Throttle position sensor is not moving.
Code 21: Coolant temp sensor or circuit problem.
Code 22: Intake temp sensor or circuit problem.
Code 30: Oil pressure sensor or circuit senses low engine oil pressure. ECU turns off main relay and stops engine.
Code 33: Open circuit in the primary circuit of the Cylidner #1 ignition coil.
Code 34: Open circuit in the primary circuit of the Cylinder #2 ignition coil.
Code 42: Speed sensor or circuit problem.
Code 43: ECU unable to monitor system voltage due to an open or short circuit in fuel system circuit.
Code 44: Internal ECU problem with CO setting or adjustment mode.
Code 46: System voltage is too high or too low.
Code 50: ECU internal memory or data problem.
Code 65: Knock sensor or circuit problem.
Code 81: Grip warmer open or short circuit.
Code 83: Thum warmer open or short circuit.
Code 84: TORS system has been activated.
Code 85: Short or open circuit in oil pressure switch.
Code 88: Short or open circuit in reverse indicator switch.
BV1
Great info, thanks for taking the time
-Steve
-Steve
backcountry
Thank's, that helped me out alot. I'm on a 2 week vacation and left the manual at home.
pat the rat
how do you know wich code you are getting
GypsyRoots
If you get an error code, you will be able to read it on your instrument pod.pat the rat said:how do you know wich code you are getting
GypsyRoots
not only I have been having trouble starting, this morning I got code 43...
man!!! I am soooo upset!!!!
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
CHECH FUSES , IF YOU HAVE BEEN BOOSTING !!!
Anyone know what code 89 is?
My error.It is code 85.Oil Pressure switch.I forgot to hook it up messing with front end.Thank You Mr Ulmer you just saved me alot of time looking around in there!
Brian
xc_phazer137
Is there a code 64? For when your Sprocket frezes under the secondary?
ANyone see this one? I did in the I500 when I went to go start it up. Day 2
Maybe code 42 would show if sensor got damaged.
xc_phazer137
You know I could have swar it was 64 Chad Geaco came over and told me what it ment. I know I had a pinched throttle line from Ice and it threw the code for that. witched matched the one for that. Butt 64 sticks in my head.
UP bushman
Hey xc_phazer137 are you sure it's not 84 that is Tors throttle switch sticking.
xc_phazer137
Nope I looked at the dealer notes today at lunch and they cleared the #64 code for track speed sensor. Why that is not listed ?? Not sure but if anyone has there gear below the the secondary clutch ice up it will throw a code.
