Hi Guys I have the variable adjust warmers now on my Nytro and love to run 1-2 bars on the gauge on warmer days and not have to play with the switch all day. With the hi and low setting on the viper are you guys happy with the warmers or do you find yourself turning them on and off allot? I know its a minor thing but I am curious. Thanks
rbell14
Oh ya! My Viper will keep the hands plenty warm on low. I have Gauntlets and generally ride with no gloves and just use low warmer setting hear and there. With my high setting my hands will cook. I had a Nytro, the Viper warmers are very good.
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
I had the same concern when i purchased my viper.
Turned out to be a non issue.
I very seldom use the high setting. Almost always on low and they never seem to get too hot for me
Team Lazy
I pretty much start out on high, then when I'm warm put it on low and forget it. If I stop to say, dig a shallow grave or something, then I'll run them back on hot again for a minute, back to low again. As mentioned, pretty much a non issue.
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Do as guys say get hot on high then run low......do miss the adjustability but not a big deal. One nice thing is no need to look just click hi or low, no looking at display little thing but nice
larrypolaris
Both of mine quit working on the last ride. Haven't investigated yet.
When working so simple. Like them a lot.
buddah
- Apr 14, 2003
- Wetmore, MI
- '17 Sidewinder B-TX LE
I used to run my Yamaha warmers on either 1 or 2 bars.......these "Cat" warmers are somewhat of a pain flipping off quite a bit so hands don't get too warm but after some saddle time it simply becomes 2nd nature..........
jsslye
- Nov 20, 2015
- Marilla, NY
- 2016 Yamaha SR Viper LTX-LE
Gone but not forgotten:
2009 Nytro RTX-SE
1999 Vmax 600 SX Triple
I had a Nytro with the Yamaheaters (because 10% voltage at idle was worthless) and having to look at the gauges to see where you were adjusting either the hand or the thumb was a, well, just another stupid idea. The Viper buttons are so much easier to use, and I only find myself going between "Low" and "Off" on warmer days. Thankfully you can do it without slowing down and looking down. It's also nice to have them actually work when you're first starting off on colder days, without an aftermarket kit, that is.
Mitch Desorcy
MAX PRO
- May 6, 2014
- Winnipeg Manitoba
- 2014 Yamaha SR Viper LTX SE
I have no issues with the hand warmers. My thumb was cold before I installed the Yamaha throttle lever and that thing is hot!! Took my glove off to check how hot that lever was and dam near burnt my thumb. And also, lever is much better
Team Lazy
Arctic Cat sells the elements and grips individually. It's simple plug and play, the connector is under the switch bloc on each side. It's a 3 wire plug, super easy. Shame on them for making something so vital that fails constantly.
09nytro
I put the spi cork under my heater elements ( cat elements )and used RSI gel grips .... Always stay on low ... Hot just gets way to hot for me ....its a non-issue really
The 17 cats have thinner grips that supposedly are warmer. Wont help thumb but I am thinking of giving them a try just for the smaller diameter.
