IceStriker
So, I bought a used Viper and I'm wondering if it's missing a side vent? There is none in the opening on the exhaust side but there is one on the clutch side. I'm talking about the opening closer to the ski, not the slotted, larger cutout above for which I have on both sides. Tried to post a picture but said the file was too large. Thanks in advance!
DennyTuna
- Jan 28, 2017
- Ohio
- 18 Winder LTX 50th
16 SR Viper RTX (red)
02 SX Viper ER (red)
97 SX Vmax 600 (red)
No lower vent on exhaust side like what's on the clutch side. Frog skin covered vent on clutch side only.So, I bought a used Viper and I'm wondering if it's missing a side vent? There is none in the opening on the exhaust side but there is one on the clutch side. I'm talking about the opening closer to the ski, not the slotted, larger cutout above for which I have on both sides. Tried to post a picture but said the file was too large. Thanks in advance!
IceStriker
Thank you, kindly. Good to know although it does look off like there should be one there. Is that designed to allow snow in?No lower vent on exhaust side like what's on the clutch side. Frog skin covered vent on clutch side only.
DennyTuna
- Jan 28, 2017
- Ohio
Are you saying you have a hole cut out on the exhaust side similar to the lower clutch side vent with frog skin?
