BlueLightning52
- Dec 21, 2023
- Nor
- Norway
- Yamaha Sidewinder 153 MTX 2020, 270 maptun kit.
Had issues a while back starting my sidewinder, only starts when turning ignition and holding gas lever slightly in, will NOT idle by itself, dies out.
Filled it up with fresh gas and
Drove to work to try and get it inside the warmth, worked great after being in the heat for some hours. And worked for a couple weeks.
Now, today when it's been outside without being started for 3 days, it has the same issues again.
Any idea what it can be? I figure fouled plugs. But strange that it happens after standing still for a while.
It has 2000km, on what I presume is plugs from when it was new.
Sidewinder 153 mtx 2020 with 270hp maptune kit.
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
Did you check throttle cable freeplay?
I have had this happen on my wife’s sled. Make sure there is no moisture in the sensors in the vaccum lines that go into the nose area by fuse box. It’s could also be the sensor on the throttle body rack.Had issues a while back starting my sidewinder, only starts when turning ignition and holding gas lever slightly in, will NOT idle by itself, dies out.
Allen Ulmer may know more. @Srxspec
BlueLightning52
- Dec 21, 2023
- Nor
- Norway
I checked just now, seems normal, about a credit cards thickness play in it. Forgot to mention, on full throttle it shoots/crackles etcDid you check throttle cable freeplay?
BlueLightning52
- Dec 21, 2023
- Nor
- Norway
I'll make sure to check those vacum lines when I get off work!I have had this happen on my wife’s sled. Make sure there is no moisture in the sensors in the vaccum lines that go into the nose area by fuse box. It’s could also be the sensor on the throttle body rack.
BlueLightning52
- Dec 21, 2023
- Nor
- Norway
Is these the vaccum lines and sensors you had in mind?I have had this happen on my wife’s sled. Make sure there is no moisture in the sensors in the vaccum lines that go into the nose area by fuse box. It’s could also be the sensor on the throttle body rack.
Yea. Also check the other sensors connections and one of them points down that it’s not plugged.Is these the vaccum lines and sensors you had in mind?
sideshowBob
Check this info out as well.
Plugging the wastegate solenoid vent?
Has anyone had there wastegate solenoid vent plugged by dealer? I have 2 winders here both with plugged vent lines both had codes and this was yamaha recommendation (both stock at the time) One is stock and runs fine The second one is tuned and is getting only 13lbs on 270 with both hurricane...
ty4stroke.com
BlueLightning52
- Dec 21, 2023
- Nor
- Norway
Will check over everything mentioned after christmas, right now it's time to relax and enjoy christmas time!Check this info out as well.
Has anyone had there wastegate solenoid vent plugged by dealer? I have 2 winders here both with plugged vent lines both had codes and this was yamaha recommendation (both stock at the time) One is stock and runs fine The second one is tuned and is getting only 13lbs on 270 with both hurricane...ty4stroke.com
And Thanks for all the tips on what to check!
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Make sure the rubber hose under throttle bodies going to the idle air circuit does not have a kink it it or a blockage from water and oil freeze.. That will plug off your idle air.
