srx700lt
I have a Sidewinder XTX 146 SE - 20, and now I'm thinking of swapping the track to a one with larger lugs. Anyone done that and has any advice?
I was planning on getting a 2 1/4 (57mm) but it appears that is not available so the next is 2 1/2 (64mm). Does that work with 8 tooth drive or do I need to go to 7 tooth?
Ylisijo
- Apr 3, 2022
- Suomi
- Other
- Yamaha sidewinder x-xt se 146
Challenger extreme 64 and original 9t 2,86 drivers it just have enough room to rotate freely
srx700lt
That is exactly what I am planning on doing. But it must be extremely close to the cooling lines in the tunnel?
And the rear bumper, is it from a 141"?
Ylisijo
- Apr 3, 2022
- Suomi
- Other
Clearance to hoses in front is 1,5cm. Rear tunnel, cooler hoses and bumper is cut 15cm shorter.
sidewinder 2018
- Feb 13, 2017
- Amston,CT
- Renegade 900 ACE,XF 9000 Crosstour
FWIW I run the Camso Hurricane 175 2 ply with #270 SS28R iGRIP racing studs.on my 2018 xf9000 146”Crosstour.over 3k currently on trac.no issues.
