RichsApex3573
- Dec 17, 2014
- 2006 Yamaha Apex Attak
Every time I back up my snowflap gets caught in the track- I'd like to cut it about half-way up but heard it may make the sled run hotter/overheat. Anyone have experience with this?
gytrapex
- Oct 5, 2014
- 06 yamhah apex gt
This is how I did mine so it stop doing that
snobill
- Nov 4, 2012
- Wisconsin Rapids , WI
- 2012 apex xtx
Yep I did that to
gytrapex
- Oct 5, 2014
- 06 yamhah apex gt
Hey it works
Get an 07 or newer style flap. They tilt back more and don't sag like the 06.
Hartatac
- Aug 25, 2014
- New Brunswick
- Yamaha Apex GT
- New Brunswick
I cut the 06 flap at the crease at the bottom. Looks good , doesn't catch as easy and still lots of flap left to keep the sled cool
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
or you can call Travis at barn of parts and get his snow flap bracket it angels it back more and is stronger then stock got one for a friends 07 and the fit was perfect and came with all the rivets needed to do the job very simple too just have to remove the bumper to do the job (4 bolts) very happy with the product. if not the crease at the botom of the flap is a great place to cut it as it gives you a straight line to use and I ran my gt like that for 2 years with no issues.
RichsApex3573
- Dec 17, 2014
GYTRAPEX
I cant zoom in on that pic, looks like just a bungie with a rivet through it? What'd you use for a backer so it doesn't pull through, large washer or something?
Steiner- is the 07 and up a direct replacement or will have to modify at all to fit?
My flap is in pretty rough shape- may just buy 07 style if it bolts right in
Hey it works
GYTRAPEX
Yes. It will rivet right on.
tomanytoyz
I have an 06 with the stock flap. All I did was custom trim the sides (for a skinny look) and cut the bottom a little - and the metal piece under I bent up so the flap is up and away ! Looks good and performs with no over heating !
Kevlar55
My 07 snow flap gets sucked under if I'm in deep snow. I plan on getting a new bracket from Travis.
Kevin.
Kevin.
CaptCaper
- Jan 1, 2007
- Northern N.H.
I trimmed both the 2010 Vector LTX and Attak at the line below "Yamaha" this works fine. No issues. Did another 07 Attak and got 10000 miles with it.
gytrapex
- Oct 5, 2014
- 06 yamhah apex gt
I hade a ratchet strap that broke took the strap part and just use that and I put a big washer on the in side so it won't pull throwGYTRAPEX
