chuckpp
- Mar 27, 2013
- Belmont N.H
- 2016 Yamaha srviper ltx dx
SMA-8JP63-00-00 OR SMA-8LY63-00-BK
tks chuck
tks chuck
Carla 123
- Feb 27, 2017
- Lester beach
- 2015 viper xtx boosted
17 zr9000 precision stage 3
The expandable tunnel bag is nice.holds quite a bit of gear.just depends on what you want it for.day trips.?overnighter?personal choice I guess.i have the expandable and windshield bag and that is all I need.
Same here. I added a net over the top of mine and removed the Plastic stiffeners from sides. The net keeps everything packed tightly in there and reminds me to close zipper so I dont lose everything on trail. Also works well for carrying a Pizza to Hotel!
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
I believe the SMA-8LY63-00-BK is the updated version of the expandable bag, the SMA-8JP63-00-00 is the original. I just got the SMA-8LY63-00-BK and it has a big heavy duty wear patch where the seat latch rubs, 106$ from Port Yamaha.
picasso
- Nov 11, 2014
- Holland, Michigan
- SR Viper R-TX DX
Wish they would have made them water proof. Everything gets soaked in there. If temps are not super frigid.
Motorboat
Agree that the expandable bag is the way to go. I can fit 3 to go boxes in it. I do like the net idea as stuff does bounce around.
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
I find the small ziplock "space saver" bags are a perfect fit in the tunnel pack, 3 pack is about 10$Wish they would have made them water proof. Everything gets soaked in there. If temps are not super frigid.
Crazy Canuk
I have a small factory bag on my STX that also accommodates small saddlebags when I put them on. It would still be nice to have extra space so I ordered a set of LinQ mounts for the Doo gear which I am waiting to get. Their stuff seems a lot better thought out. I already have a fuel caddy for it and might pick up their 21 litre bag as well. An option you may want to consider. The mounts I ordered were $100. Leaves it open for a lot more options. I will post picks when I get it all setup
Crazy Canuk
Good idea. I keep all my stuff in smaller ziplocks (tp, belt, etc.) so it will stay dry. Will ask the wifey to pick some of the bigger ones up next time she is shopping.I find the small ziplock "space saver" bags are a perfect fit in the tunnel pack, 3 pack is about 10$
TILAM1
- Jan 26, 2017
- 2017 SR Viper R-TX-SE
- Eastern Ontario
Just picked up mine today. The dealer said if you sell the sled, and want to keep the bag, remove the riveted dowel pins as they can't be bought separately. Getting up my nerve to drill the tunnel.I believe the SMA-8LY63-00-BK is the updated version of the expandable bag, the SMA-8JP63-00-00 is the original. I just got the SMA-8LY63-00-BK and it has a big heavy duty wear patch where the seat latch rubs, 106$ from Port Yamaha.
Mike P
- Nov 18, 2015
- Berlin CT
- Sr Viper R-TX SE
- Berlin CT
What Bag did you get?Just picked up mine today. The dealer said if you sell the sled, and want to keep the bag, remove the riveted dowel pins as they can't be bought separately. Getting up my nerve to drill the tunnel.
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
On my XTX I just drilled out an existing rivet and installed the bobbins
TILAM1
- Jan 26, 2017
- Eastern Ontario
SMA-8LY63-00-BKWhat Bag did you get?
TILAM1
- Jan 26, 2017
- Eastern Ontario
SMA-8LY63-00-BK
All installed and here are a few pictures. Expanded and regular. I also modified the seat latch. I rounded off the corners and took a piece of tubing, slit it lengthwise and covered the metal edge. Held on with zip ties. Should stop tearing the bag but the bag does have a heavy patch in that area too. Sorry it's a bit fuzzy.SMA-8LY63-00-BK
ksiesel
- Mar 25, 2016
- Indiana
- 2015 Viper RTX-DX
- Indiana
The rivets and spools can be purchased from CAT. I bought some this spring from Country Cat to mount a saddlebag that I bought used.Just picked up mine today. The dealer said if you sell the sled, and want to keep the bag, remove the riveted dowel pins as they can't be bought separately. Getting up my nerve to drill the tunnel.
https://www.countrycat.com/arctic-cat-6639-154-pair-of-spools-with-rivets-tunnel-bag-hardware
