rough rider
Well im going to order the star suspension kit for my nytro, wanted to get a new sled next year, but dealers wont trade and everyone wants it for nothing, so i am going to keep it and do some suspension upgrading and put a new graphic kit on, kind of change things up alittle for next year. so how many people are using this star kit, ??? and does it make the xtx rear suspension ride alittle smoother over the stutter bumps and suck up holes alittle smoother, I had shocks revalved by pioneer, did a nice job, sled way better than stock setup, but im still looking for a plusher ride ,or isnt that possible on this skid??? All my yamaha buddies are switching over to ski-doos, but havnt had steller reliability with them, but those things ride plush. No im not going to ski-doo yet ,been riding yamaha for 24 years cant change yet would just like to get closer to the scooby doos ride. also what ski-rubber works with the pilots without any cutting, and how thick shim under rubber do i need. Thanks
stubb111
the star kit works very well on the xtx, it makes it more progressive and seems to make it turn better also (feels like the pivot point of the sled is moved forward about 2ft....seems like it turns from under your butt instead of the back of the track) another nice thing I like is there is a lot more weight transfer allowing the front end to float over bumps with a hit of the throttle. star suspension suggests center shock to be modified (revalve & shorten of the shock) to allow shock to work efficiently with the revised linkage ratios because of the increase in the progressiveness of the new linkage setup. I would suggest having star do your revalving as, they know what works best with their kit, and prices are very reasonable. pioneer motorsports sells a kit for installing pilot ski on your Yamaha, I run 1/4" spacer under rubber. I also run stock ski's with snow tracker (semi aggressive) setup on both stock ski and also on stock mountain ski depending on conditions. with trail setup it will corner with anything else no problem but, it is very sensitive to changes.
there is a very good link on suspension setup in tech section, a lot of people chiming in on setups and opinions...very good reading.
cheers
cheers
00-NUKE
rough rider said:Well im going to order the star suspension kit for my nytro, wanted to get a new sled next year, but dealers wont trade and everyone wants it for nothing, so i am going to keep it and do some suspension upgrading and put a new graphic kit on, kind of change things up alittle for next year. so how many people are using this star kit, ??? and does it make the xtx rear suspension ride alittle smoother over the stutter bumps and suck up holes alittle smoother, I had shocks revalved by pioneer, did a nice job, sled way better than stock setup, but im still looking for a plusher ride ,or isnt that possible on this skid??? All my yamaha buddies are switching over to ski-doos, but havnt had steller reliability with them, but those things ride plush. No im not going to ski-doo yet ,been riding yamaha for 24 years cant change yet would just like to get closer to the scooby doos ride. also what ski-rubber works with the pilots without any cutting, and how thick shim under rubber do i need. Thanks
Fot the XTX it's a "MUST DO" if you plan on keeping the stock skid. The Star Suspension was my number 2 upgrade after the OFT Relocator, and I have LOTS of upgrades. It allows the rear skid to work like it should.
yam429
- Jan 18, 2009
- Saint Michael, MN
- 2009 Nytro XTX, 2010 Vector LTX, 1981 SRX 440, 1989 Inviter, 1991 Snosport, 2004 Snowhawk
- Saint Michael
X2
Beenba
Yep. Star kit is #1 mod, along with #2 the tuner ski's. Whole new sled. Do a little searching and you can find likely 10 threads about the star kit and various reviews (all good from what I have seen). My next #3 mod is the vector gauge.
Oh and yes, have star shorten the stroke of the center shock a bit, as this doesn't actually affect the suspension at all, but will save you BIGTIME when you blow your limiter straps and have your entire rear shock and linkages blow apart. Again search my threads and you can find what happened to me (learned the hard way).
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
- 2015 Viper XTX LE MPI Turbo
2022 Expedition Extreme 850
Will a Star kit work on an 08 MTX 153? It is basically the same as the XTX suspension. Mine is not all that good in the bumps.
stubb111
rough rider
00-nuke If u dont mind me asking what is the usa price of kit, it shows 300.00 canadian, is it the same for us.
Beenba said:Yep. Star kit is #1 mod, along with #2 the tuner ski's. Whole new sled. Do a little searching and you can find likely 10 threads about the star kit and various reviews (all good from what I have seen). My next #3 mod is the vector gauge.
X2
I found out the hard way too. Broke the straps and crushed the rear shock and linkages. Luckily I was able to send off to Star and get the shock repaired. Had the center shock done at the same time with the spacer. Also doubled up the new straps this time.
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
Robert Veronneau from Star Suspension informed me they now have a kit for the MTX suspension. However, installation instructions are not ready yet.
Is this kit difficult to install??
Redbeard
- Oct 14, 2011
- IN
- 2012 Apex, 136 M20, PB80
2008 Vector, 136 M20, PB80
maxxp said:Beenba said:Yep. Star kit is #1 mod, along with #2 the tuner ski's. Whole new sled. Do a little searching and you can find likely 10 threads about the star kit and various reviews (all good from what I have seen). My next #3 mod is the vector gauge.
X2
Did you install new OEM limiter straps or use another brand?
Beenba
I put new OEM on mine after they broke and I damaged everything.
I also doubled them up and put on 1800km this year with no problems. I did watch them like a hawk though.
Redbeard
- Oct 14, 2011
- IN
Beenba said:I put new OEM on mine after they broke and I damaged everything.
Does doubled up mean you used four limiter straps instead of two?
upei93
- Apr 27, 2008
- Dalhousie, NB
2009 Nytro XTX
northernsledder.jk said:Beenba said:I put new OEM on mine after they broke and I damaged everything.
http://www.ty4stroke.com/viewtopic.php? ... ght=straps
MCApex44
- Mar 30, 2006
- Western New York, Chautauqua County
- 2014 Viper RTX SE (sold)
