Bluebullet
- Mar 19, 2005
- Augusta, Maine
- Maine
Tried to start my sw yesterday. lights and dash come on, fuel pump on, no codes. Charged battery for a while even though it showed fully charged. removed seat all connections good. relay clunks by battery...... no starter spin???? never seen this issue before. sled is in my enclosed trailer. I need to back it up to get the hood and panels off.
Thanks Terry
Thanks Terry
Turboflash
- Mar 18, 2019
- Southern MN
Sounds like starter issue. Connections tight at starter? Maybe corrosion between brushes and commutator? Gonna have to drag sled back in order to get side panels off. Try taking a long 3/8" extension (3') and putting it on the starter (I think you can access it from clutch side?), bang on extension with hammer to shock starter while someone is trying to start it.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
I'd load test battery, myself. Might show fully charged yet not enough amps to start.
You can use an ohmmeter to verify
earthling
Battery voltage should hold when you turn the key (12.6 or more volts), if it drops at all, you have a battery problem. It would only drop normally when the starter kicks over.
Doc Harley
- Oct 17, 2016
- Here & there
1) pull fuel pump fuse
2) hook up meter to battery
3) crank it over
4) watch voltage drop
5) let us know the # it drops to
My battery drops to 10.9v and still starts my sled. which is dangerously close to needing replacement. Ill review this in the fall.
3) crank it over
Bluebullet
- Mar 19, 2005
- Augusta, Maine
- Maine
Thanks Guys, Update..... Starter rolls over slow with charger on 10 amps. voltage drops below 12 volts under load when starting. I ordered a new battery and will give it ago again upon arrival. Good news is the old apex starts and purrs like a kitten!
zxtyler
My sw will not start either. The relay just rattles like crazy With or without boost. Is the relay bad or maby starter stuck? 2020 yr 3600 mi.
have you tried jumping the 2 big terminals on the starter solenoid? that will confirm or eliminate starter.My sw will not start either. The relay just rattles like crazy With or without boost. Is the relay bad or maby starter stuck? 2020 yr 3600 mi.
earthling
If the relay is rattling it may be a sign of low voltage as you don't have enough voltage to hold the relay closed. (energizes, de-energizes). If you jump the relay, the starter should at least try to engage. But start with the battery.
Bluebullet
- Mar 19, 2005
- Augusta, Maine
- Maine
New Battery installed and starts perfect! Apex battery lasted 8 years, sidewinder barley 3 years.....oh well
Doc Harley
- Oct 17, 2016
- Here & there
Checking everything else but the battery is kinda like putting the cart B4 the horse.New Battery installed and starts perfect! Apex battery lasted 8 years, sidewinder barley 3 years.....oh well
Glad you're up & running ...
zxtyler
New battery repaired it thanks men!
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
Are you saying you needed to.....I need to back it up to get the hood and panels off.
Thanks Terry
"Back it up Terry!"
Oh boy, we need snow. I'm goin' crazy over here.
