flyingpig
I had my Apex GT out in a large field day before yesterday. I was running it back and fourth several times and in a half mile run. I managed to get it up to just over 100 indicated. So I decided to go back home and plug the GPS in. I went back to the field with the GPS mounted and ran several passes over this 1/2 mile stretch. The max speed I could attain on the GPS was a whopping 89.6 mph. I'm not disappointed yet because it was in about of foot of loose snow and I am not picked. I really thought that the Apex GT would be much faster than my SRX. I will let everyone know when my son comes home from Iraq what the outcome is. Enjoy your sleds guys!
BA APEX
when i did check speedo with a radar in an ols drag field, I had 103 radar to 118 on the dream meter. i did get 105 a while later. I think on ice you will see decent numbers out of the new Apex.
flyingpig
How long of a run was it and are you picked?
dirkdiggler
Suspended
The Problem is the conditions your running in. With the Long travel suspension and the attack angle of the track your not going to see great top-end numbers in that deep snow
I suggest you go to a ice covered road or a Lake with no snow on it to do MPH tests. Deep snow is a killer for the RX-1 and the APEX.
On a ICY road I've seen as much as 137 on the dream meter on my old RX-1 which is about 118 MPH on the Gun. In deep snow it would pull about 115 on the dream meter. which is less then 100 mph on the gun
flyingpig
I had made mutiple paths packing down the snow each time. But isn't 1/2 mile in a field long enough stretch to know what this thing will do?
BA APEX
Yes picked, 144 up the middle with 1.375 woodys. total of 70 miles on sled at end of the day. rpm's may have just gotten to 10k. very little snow. needs more miles.flyingpig said:How long of a run was it and are you picked?
about 1000' of run before shut down
link on one of the runs: http://x402.putfile.com/videos/d3-33022153228.wmv
flyingpig
Hmm! This was 2500' of run. I'm unpicked and my rpm were 10,500.
Dano
Big difference on ice or any hard base. SRX doesn’t pull big numbers in loose snow as well. Mach Z’s, thundercats ...they are all the same. Its safe to say that most top speeds you hear or read about are best case scenarios. JMO
Dan
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
anyone done the speedo "2 teeth thing"..???...on an apex yet?...i want to know how close this brings apex speedo to actual....I know theres another thread about this but i think most who did it were rx1s...want to be sure its still 2 teeth for apex.
thanks guys
dan
thanks guys
dan
flyingpig
I'm sure your right guy's! Thanks
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Did one tooth today,but unable to test yet,maybe in a week or so.machzed said:anyone done the speedo "2 teeth thing"..???...on an apex yet?...i want to know how close this brings apex speedo to actual....I know theres another thread about this but i think most who did it were rx1s...want to be sure its still 2 teeth for apex.
thanks guys
dan
SledFreak
- Feb 7, 2005
- Ontario. Canada
Unless you are on hardground, use are basically wasting fuel. You will never get a true indication of what it can do on soft snow.
Dano
thanks guys
dan
Hey Dan, I might try grinding off a tooth, but I’m a little hesitant on how it will effect the odometer. The odometers seem to be accurate when compared to my GPS. I wish Yamaha would do the right thing and calibrate the Speedos. It bothers me when I’m doing 135 yamaperhour and every other OEM can get it much closer to reality. 5-10 mph deeficiancy in not bad, but 15-25 is not acceptable.
Dan
Dano
mnmsnowbeast said:Did one tooth today,but unable to test yet,maybe in a week or so.
let us know how this works with the odometer as well...thanks
Dan
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Yup i sure will,i want to know what it does to the odometer too,but i run w/gps most all the time anyways and gps will give me the most accurate milage anyway,it even gives time running so cool new toys lol,ya i took just one tooth off,just reving it on the jackstand it seems lower than before,soon we will get some snow,i hope..lolDano said:mnmsnowbeast said:Did one tooth today,but unable to test yet,maybe in a week or so.
Dan
- 29K
