neonphil
Turbo calculator and more,Snow Fever I think you find this interesting
http://www.turbofast.com.au/TFmatch.html
Snow Fever
Thanks Rx-Warrior I typed in 1000cc @ 10200 rpm with 8lbs boost and an intercooler and it says only 176hp I hope the ain't so cause I have no cooler and only 6lbs boost? I'm going to spend some time on there though and see what I can find. It does say the same Garrett turbo as the guy in califonia told me which this one crosses over to so hopefully its not too far off.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
a twin turbo 1000 with an intercooler spinning 10,800 rpm is 377 hp :lol:
jtssrx
this is what I got for 10200 intercooled with 1000cc.
MAKE TYPE HP Rating TURBINE HSG A/R
Garrett GT25 260 0.63
- Apr 17, 2003
- Menno, SD
- Menno, SD
and now if you could just bore the rx1 out to 8000cc's and twin turbo it at 34 lbs of boost you could have 3,356 hp!!!! now that thing would fly!
neonphil
Snow Fever I have read that with a turbo they are running the rpm to 11200 I think the revlimiter kicks in at 11300.And at 11200 It brings the HP to 193 with 8 lbs and intercooler I could live with that.
Snow Fever
RX-Warrior, Dyno-tech says like 220hp on 8lbs boost intercooled and it produces the best Hp and Torque combined around 10,100. You get more hp (very little) at higher rpm but the torque is going down. (the torque is much higher down around 7000 but thats not where it would be pulling a hill) the best trade off Hp to Torque looks like to me 10,100 +/- 100rpm thats what I'm going to shoot for any ways.
neonphil
I bet the motor will live longer to.
