yellow rider
- Aug 4, 2014
- yamaha
From what I 've read they have sold a lot of them, but I yet to find where I can read reports on them. What do you guys that bought them think of them?
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
- 2017 Sidewinder BTX LE
2012 Nytro XTX 1.75
I can't tell you about there clutching because I am running Thunderproducts but the tunes are phenomenal and Ben is very supportive I have the map pack with flasher and datalogger with antilag and it is very easy to use. I run the Max pump tune with a splash of race gas just to be safe even tho it isn't required if you have quality pump fuel. If you thought your sled pulled hard before it will be a monster with a TD tune!
**sj**
I can say this....if anyone is considering a flash....they have built their tunes on the ground, fully tested in the temps we ride in and Id bet nobody has flashed more tunes than TD....I was originally on the fence....but once I investigated......but I'm definitely going TD!
Beerman
- Nov 22, 2004
- Plymouth, MN
- www.loyalshepherd.com
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
Started with EcoTrail, SuperQuiet muffler and Dalton weights with 0 miles on my sled. Could not be happier. Now have the flasher, tune pack, anti-lag, CAI and the Max 17 tune, but will likely move to PowerTrail as I don't want to worry about carrying 2 cans of Torco everyday we do 300 miles.
yellow rider
- Aug 4, 2014
- yamaha
How quiet is the super quiet?
34pontiac
I have CAI also, but at the moment not compatible with Powertrail.Started with EcoTrail, SuperQuiet muffler and Dalton weights with 0 miles on my sled. Could not be happier. Now have the flasher, tune pack, anti-lag, CAI and the Max 17 tune, but will likely move to PowerTrail as I don't want to worry about carrying 2 cans of Torco everyday we do 300 miles.
Powertrail only if you use stock air box I was told. So hoping he makes a CAI version for Powertrail because I also don't want to carry torco around.
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
2014 SR Viper XTX SE (Sold)
I'm running the Max 17 tune on asphalt and it rocks. Tune with CAI, Antilag, and AFR. Thunder Products Clutching. 9.53 @ 137mph in the 1/4 mile. Setup for braket racing.
Beerman
- Nov 22, 2004
- Plymouth, MN
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
Depends what you call "quiet". It's a lot quieter than the OSP muffler, which is very similar to TD's TurboForce and a couple others. The SQ is the way to go for me as a trail rider. I am wondering how much more HP Sandale's HyperFlow makes, same muffler but 3" vs 2.5".How quiet is the super quiet?
Beerman
- Nov 22, 2004
- Plymouth, MN
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
I asked Ben that on his FB page - he said he can make a PT CAI tune by starting with his Max 16 CAI. I'm in the same boat as you - I have the CAI and would rather not have to carry Torco around with me, I'd need 2 cans on the big mile days and that's a lot. If I could get away with 1 can for 4 tanks it might be different.I have CAI also, but at the moment not compatible with Powertrail.
yellow rider
- Aug 4, 2014
- yamaha
Does anybody have the sandale 3" or even 2.5" that can comment and who's tune?
34pontiac
It would be great if he could make a CAI for Ecotrail and Powertrail and then include it in the Multi map package and then give it to the guys that already have the Multi package like myself.I asked Ben that on his FB page - he said he can make a PT CAI tune by starting with his Max 16 CAI. I'm in the same boat as you - I have the CAI and would rather not have to carry Torco around with me, I'd need 2 cans on the big mile days and that's a lot. If I could get away with 1 can for 4 tanks it might be different.
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
2012 Nytro XTX 1.75
He can make any tune cai compatable you just have to let him know that's what you have I'm running the max pump17 with 3in side exit straight pipe and out the hood cold air intake and it runs awesome last night at the track we ran a best of 9.30 and consistently 9.33-9.38 at close to trail weight and 180lb rider! Thanks BEN!
yellow rider
- Aug 4, 2014
- yamaha
I'm interested about the clutching and trailability with the additional boost. How does it effect gas mileage? Is the boost just an increase where the 9.9 psileft off or does it build sooner?
Turbo Dynamics
- Jun 16, 2016
- Gatineau
- 2017 Yamaha Sidewinder
2014 ZR9000 turbo
- Gatineau, Quebec, Canada
- turbodynamicscanada
- YOUTUBE
- TurboDynamicscanada
That is flying for only 17 psi of boost on a trail setup (minus the straight pipe).He can make any tune cai compatable you just have to let him know that's what you have I'm running the max pump17 with 3in side exit straight pipe and out the hood cold air intake and it runs awesome last night at the track we ran a best of 9.30 and consistently 9.33-9.38 at close to trail weight and 180lb rider! Thanks BEN!
yes we sold a very large amount of kits last year, lots of positive reviews. For the highest amount of review check our facebook page.
**sj**
awesome! keep pushing those numbers
