Muleskinner
I want to take the clutch off my Viper to try it on the Nytro to see how the heel clickers work. Will it fit or does it have different dimensions?
Mtnviper
Vendor
Same basic clutch, just different calibration. (weights, spring, etc)
Turk
Tech Advisor
Afrtermarket weights will work but oem,s won,t.
terret725
you have to callibrate the clutch to do what you want using the differnt componets, a clutch set up for one sled wont work well on another. the profile of the wights, the actualy weight of the weights, how the weight is distributed in the weight, spring rate, preload of teh spring and size of the rollers all have to be tuned for the motor and ur actual needs. and thats just the primary. canging settings and springs and ramps on the seconday also have effects.
when changing clutch componets to an unknown you need to do alot of testing and tuning to get exsactly what you want.
Muleskinner
Thanks, just wanted to make sure there wasn't a change in the crankshaft taper or something not visible or easily measurable.
Muleskinner
Put it on today and it works great. Weighted up the arms and changed secondary preload. Woke it right up, pulls hard right to shift out. I couldn't get the drag n' fly's to work but the original heel clickers sure do. Seems to be a better profile.
terret725
double check your engagement rpm and your full shift rpm are good. no need blowing your motor because you are running too high of rpm at full shift.
