Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
When I called mpi about the controller I was telling Jon about the time I had with the early build. He kinda hesitated and said something like you may have the last of the good ones for boost. Now I know what he meant.This could just be the warning MPI put out about the misprogrammed controllers?
tator
if this will be a recall, will it be for all 16s that have the weaker rods (new engine)? or just the ones that have had "factory" turbos added. if not all, be aware down the road looking at used 16s if you want to turbo them.
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
Yamaha may not view this as a problem at all, their factory authorized turbo makes 4.5 pounds of boost and would most likely not cause a failure....
I agree!
CustomApexMan
Sounds like aftermarket rod sales are going up
Sunvang
- Jan 14, 2009
- Telemark
- Norway
- 2018 Arctic Cat Hardcore EVO
2017 Yamaha Sidewinder BTX LE
Can't find anyone making them yet.Sounds like aftermarket rod sales are going up
Sportsterdanne
The new mcx 190 kit uses a different turbocharger a Mitsu 14T and must be checked and adjusted on the wastegate rod some kits are overboosting straight from the box.
stingray719
One guy posting an email does not make a disaster. My Phazer blew the MCX box and I ordered one from MCX overseas, and it came with a program that was way lean mid range. When I complained to an American supplier for MCX they told me I had to pay to have it reflashed......lol. So I put an adjustable boost enabled automotive fuel regulator on and ran it. If I had not had an AFR gauge I might be here saying the Phazer had bad rods.............. Still fuming over MCX service on that deal it was not a cheap controller.
Then again there might be an issue but why only MCX and why are we not hearing about it through other channels?
It's the real deal. The new rods have been pressure tested and it is way weaker. There have been some broken rods. But they are testing like crazy to figure it out. But it seems like a stronger rod is the solution.
The 190kit have not been failing, but its still under the loop.
Sunvang
- Jan 14, 2009
- Telemark
- Norway
- Nov 29, 2009
- sabattus, maine
Yikes. If this is indeed true all those guys crying because they preordered and didn't get the new engine don't have much to cry about anymore
apexgturbo
- Feb 9, 2012
- terrenceville
- 2008 Nytro,2009 Nytro mtx,2006 apex drag sled
Why don't Yamaha just get Carrillo to build there rods.lolAs said, this is not the boy who cried wolf.
First picture is last years rod, that hade 11tons of pressure on it, second picture is 2016 rod with 7ton of pressure.
smoothride
No but the resale of my early order ltx le just when up!Yikes. If this is indeed true all those guys crying because they preordered and didn't get the new engine don't have much to cry about anymore
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
First picture is last years rod, that hade 11tons of pressure on it, second picture is 2016 rod with 7ton of pressure.[/QUOTE
See if read this correct. You bent these rods in a press and not in an engine.
