roy_kesslers
Im installing a set of whal bros extroverts on my 2012 nytro xtx. i was wondering if someone could give me the measurements i need to press them on. thanks.
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
Contact Ulmer racing, he will help you out. I have the measurements but not with me and it might be different for the xtx. Are you trimming your rails and running anti stab kit?
roy_kesslers
prob going to trim the rails. but not sure about anti stab. who makes a good anti stab kit?
sonds
- Oct 7, 2008
- Golden Valley MN
- ductworksmn.com
- 08 T-Nytro
roy_kesslers said:prob going to trim the rails. but not sure about anti stab. who makes a good anti stab kit?
Whal Bros.
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
Yup Wahl bros
sleddingfarmer
Dont forget to mark the center of your shaft before you press your stock drivers off.
I don't remember exactly what the measurement was, I think something like 3 or 3 1/2 inches each way from center is where the driver should be. But whatever it is, the procedure is pretty straight forward if you have the center marked well before removing them. If you don't have the center mark, I don't know how to do it.
arteeex
Just a slight correction... It's not the center of the shaft you want to mark, it's the center point between the currently installed drivers. The divers are a offset from the true center of the shaft.
And, use a scribe to mark the shaft. Marks from a Sharpie will be wiped off when the driver goes by.
Straight_up_XTX
If we can get this measurement can we have this added to the FAQ section? I know this is something I plan on doing this season as well.
having that measurement available without having to search would be great.
xrrider
Did mine a few days ago. Ulmer supplied me with these measurements.
From the clutch side of the driveshaft to the center of the driver should be 4 7/8". Then from the center of the driver to the center of the next driver is 8 7/8".
I followed these measurements for mine and they were right on the mark.
ULMER
ULMER
BADSLED
- May 13, 2004
- Syracuse, NY
- 2012 Nytro MC Xpress 270
2011 Apex SE
2021 Sidewinder LTX SE - SOLD
What's the anti-stab kit to be used with extroverts?
Dimebag
Here you go.
Scroll down to Alatalo's post in this thread..
http://www.ty4stroke.com/viewtopic.php? ... c&start=30
Alatalo
My measurements are obviously for Ski-Doo extroverts, but the measurements to the center should work with any brand.Dimebag said:Scroll down to Alatalo's post in this thread..
If you have got a 2012, please also scroll down to the last two posts in that thread. There is obviously a length difference between the 2012 drive shaft and previous drive shafts.
sleddingfarmer
arteeex said:Just a slight correction... It's not the center of the shaft you want to mark, it's the center point between the currently installed drivers. The divers are a offset from the true center of the shaft.
Good call! Forgot that little detail
