nytrochris62
poor farmer/logger
- Dec 3, 2012
- Saskatchewan
That's for adjusting your weight transfer.
nytrochris62
Ok, I'm guessing its to keep the skid aligned and straight also? With the coil springs off this part moves in and out easily.....it that how its supposed to be?
Are there stronger coil springs that I can install to help the rebound? I'm a big guy.
poor farmer/logger
- Dec 3, 2012
- Saskatchewan
Not really. More just changes the pivot point so you either get more transfer to the rear or less so there's more weight on the front.
There's stronger springs available but a shock revalve is probably better. Lots have done the starts upgrade as well. You'll never get all the rebound back on a nytro. Siting on the floor flat typically there's around a half to one inch of drop in the rear suspension. As its worked and warmed up that number usually drops some.
nytrochris62
I'll have to look into some stronger springs. It looks the 2007 apex has some stronger ones.
