pay2play
I'm planning to update from a 2004 Aluma 12 foot ride on/off trailer. I bought it used in 2007 and it's been good to me. I'm replacing the wiring harness that has given me some challenges, but I expect that will be sorted out and make a good trailer for the next guy. I know I want an inline trailer, but am having trouble deciding on the size, features and options that I want. Ideally, a trailer that can do it all would be great and would last a lifetime of snowmobile trips, furniture moving, lumber hauling and side x side summer running. But, I don't own a side x side and I'm not sure I ever will. I own two sleds and can't decide if I'm responsible for hauling my buddies sleds too. Reasonably, a three place 23x7 or 7.5 is my likely size. I will likely choose a Neo or an R&R for value. I would like a radius top for extra height but I don't have a really tall garage when I would want to work on it in a covered area. So, my question to you is, what would you change about your trailer now that you have used it? Pictures appreciated.
YamBam
I wish my trailer had vented sky light. It is dark inside when in the pole barn with only side door open. Also dark outside with doors closed.
gitrdun
Skylight or couple of rectangular windows on the side wall near the top would be a good idea. All added cost though. I did not put a couple of fuel doors which I thought I could get by without. I'm sorry that I did not request those. A good tip for anyone ordering a new trailer is, try to get the roof made out of as few seams as possible. As good as the caulking may be, manufacturers recommend replacing it every few years, for good reason, it does come loose. You could also request that they use that Commercial Roof and Leak Repair Tape instead of caulking, fairly pricey but supposed to last. I just bought two 50' rolls to redo mine completely.
pay2play
Good advise!
Agman 57
- Dec 28, 2006
- Fostoria, Ohio
- 2018 Apex XTX LE, 50th Ann.
2018 Sidewinder LTX LE, 50th Ann.
2017 Sidewinder BTX LE
1992 V-Max 4 (Modded)
2002 ZR 120 G-daughter's
planner
I got a new v nose double couple years ago. Front and rear drive on and drive off doors plus side access . I always use reverse and back sleds out so front drive off door goes mainly unsed. What was a problem is tie down and storing gear in front of trailer. Load sleds and always had to climb over them to get to the front to tie down or store stuff . Last year took trailer back to manufactuerer and had them put door in front V similar to a side access door. Makes storing stuff and tie town easy.
pay2play
Good advise!
tie downs for sure. once I insulated the roof on mine and added some lights it was fine inside. 2013 united enclosed 8'6" wide and 25' long. just need more truck now to pull it.
