dannyy
- Feb 16, 2011
Hi !
I have a 05 Yamaha Warrior turbo.
365cm length and 44mm belt. I have a strange noice in my suspennsion....
Sounds like the belt is "scratching" in the tunnel of my sled.
Broken suspennsion ? Need help
Best regards from Norway
DV8
Need more details, Also need to fill in your location, Site requirement.
Since the belt is not in your tunnel, We need some more details, does it do it all the time? just on the gas? what kind of turbo kit do you have?
has performance changed? Any mods to skid or tunnel?
dannyy
- Feb 16, 2011
Its making a scratching sound when i hit bumps.
Its a mcx 240Kitt , i have adjusted the boost to 1.1BAR
Sounds like the hole "suspennsion" hits the tunnel :/
But on flatt water it`s no sound....
sobfrogg
It sounds like he is refering to his track. If that is the case yes something could be broken in your suspension. Track could be to loose. Tunnel protectors could have broken away.
Lots of things to check.
