603NytroXTX
- Aug 19, 2012
- Salt Lake City
- 2009 Yamaha Nytro XTX
2010 Yamaha Apex LTX-GT
- Salt Lake City
So....long story short I did a 1.75 track swap with extros etc to update my 09 XTX to 13' spec. Looks like I didn't put enough Loctite on my new drive shaft bolt because I just found this beauty. I read about people not even putting that bolt in and I guess I should have listened. When I was doing the swap I had the broken bolt and did 5k miles with no issues. The bolt that drilled its way through the cover was just sitting in the fairing below. I have no idea how long I rode with it like that. Time for a new housing $154.00 later
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Been down that road. I put a rubber plug in it and put silicone around it
Sent from my SCH-R530X using Tapatalk
603NytroXTX
- Aug 19, 2012
- Salt Lake City
- Salt Lake City
So you never ran into any issues without the bolt? How many miles would you guess. If I remember correctly the only thing that bolt does is hold the collar/sleeve on the shaft and keep it from touch the housing/cover
APEX 06
- Apr 30, 2009
- Sheboygan, WI
I put the bolt back in on my nytro and Red loctite with loctite primer
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Wouldnt the oil pour out of the chaincase with the hole in the side? MS
APEX 06
- Apr 30, 2009
- Sheboygan, WI
Not with the rubber plug and silicone on it.
603NytroXTX
- Aug 19, 2012
- Salt Lake City
- Salt Lake City
Great mid-season fix! Seeing how I still have 6 months till I can ride I think I'm going to get the new housing/cover but good to know that it worked for you. Thanks for the responses
yamahamm
- Oct 9, 2009
- Norway, Salangen, Troms
- Norway
- 2008 yamaha nytro mtx mcx 270
Just get it welded.
been there, took apart and inspected everything, found the c-clip that is suppose to stop the bolt from coming out if it does loosen. From what I see the bolt holds the spring,bottom gear in place during chaincase assembly. If it falls out during operation you do loose oil but nothing else happened, maybe I just got lucky. Drilled threads to hold a plastic pipe plug. No I have an inspection hole. haha
That bolt is what keeps the driveshaft where it's supposed to be. If for example the set screws were not tight on the left side driveshaft bearing, then the drive shaft could move to the left.been there, took apart and inspected everything, found the c-clip that is suppose to stop the bolt from coming out if it does loosen. From what I see the bolt holds the spring,bottom gear in place during chaincase assembly. If it falls out during operation you do loose oil but nothing else happened, maybe I just got lucky. Drilled threads to hold a plastic pipe plug. No I have an inspection hole. haha
Thank you, I wondered about this and I did remove my speedometer sendor/pickup gear and inspect that bearing. I grease it every year and it hadn’t moved during this episode. the set screws were tight And shaft didn’t move. But something had to have forced the screw to back out. I keep checking through my “new inspection hole” 2,000 miles now and hasn’t loosened yet. Sled does have 21,000 miles. 2012 venture GTThat bolt is what keeps the driveshaft where it's supposed to be. If for example the set screws were not tight on the left side driveshaft bearing, then the drive shaft could move to the left.
If I remember correctly yours has the longer drive shaft and end adaptor to match.
I would just conclude that the last time this was apart, the bolt may have been put back in without loctite.
Factory spec does call for this bolt to have loctite.
In addition, use brake clean and compressed air to clean the threads, bolt and in end of shaft as oil residues negate the locking effect of loctite.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Mine did the exact same thing. Wound up JB Welding the hole and putting orange Loctite on the bolt along with a new C-clip. Stronger than blue but not as strong as red.
