TY 4 Stroke - Totallyamaha Forum Index
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
MemberlistPosting Rules  MemberlistTY Chat SearchYamaha Parts FinderMemberlistOn-Line Store MemberlistVIP
Log in to check your private messagesActive Topic (24h)  (12h)  Log in to check your private messagesMapMemberlistTY.NET Classifieds Log in to check your private messagesTY Webmail
 MemberlistTY Tech
MemberlistTY Home
MemberlistTY Forum
MemberlistATV Forum
RS Nytro Proaction CK 121 to 144. Need advice
Post new topic   Reply to topic    TY 4 Stroke - Totallyamaha Forum Index -> Skis, Studs, Tracks and Aftermarket Suspensions
View previous topic :: View next topic
Author Message
Bradford
PostPosted: Wed Nov 16, 2011 5:54 pm    Post subject: RS Nytro Proaction CK 121 to 144. Need advice Reply with quote
I've installed TracksUSA 121" - 144" tipped up rail extensions and extro drivers and now I'm having a bit of an issue with track adjustment. I read on here that these extensions change the geometry of the skid and cause the track to tighten as it moves through its travel. So, to figure out how tight I can go on the track adjustment, I removed the springs and completely bottomed out the suspension by jacking it up with floor jacks. Problem is, with the nuts removed from the adjusters and the axle moved ahead as far as it can go, the track is tight just before it bottoms out. If I put extra weight on the sled, it will actually bottom out so I think it's Ok at this point. When I remove the jacks and allow the skid to drop, the track has 5/8" free sag and 1-7/8 sag at 22#. Here's my questions:
1. Is the track too loose @ 1-7/8" at 22#?
2. Will it balloon too much to stud? If I do stud it, it will just be for safety so I would stud it on the inside of the rails and not toward the center
_________________
06 RS-Nytro-"XTX" 144 via TracksUSA
Wahl drivers
Yamaha mountain skis
Bergstrom Tripple Points
Shocktec shock valving
Back to top
View user's profile Send private message
kinger
TY Lifetime Ads Member
PostPosted: Thu Nov 17, 2011 8:13 am    Post subject: Reply with quote
Those are good questions. We'll need a proactive expert to help you but I know your right in stock form the track tightens as its compressed and that gets exaggerated when you go to 144, you might have to relocate the suspension to get it to work right or at least better.
What size track and studs were you thinking?
_________________
Like Pier Genius on facebook!
http://www.facebook.com/pages/Pier-Genius-inc/158803517486930
Predator GT-S, MPI 10lbs, 9T extros, 151" ZX2, 13.5" predator track, powderhound skis. Gems settings M1=2, M2=2.5, M3=5, M4=4.5, M5=1, M6=8
Back to top
View user's profile Send private message Visit poster's website
Bradford
PostPosted: Thu Nov 17, 2011 3:15 pm    Post subject: Reply with quote
The track is 1-1/4". If I do stud, I won't go any longer than necessary. I'm looking for safety more than performance
If its not going to hurt anything, I'll leave it the way it is. I actually ran it last year for about 500 miles with the current setup without any problems that I'm aware of. I'm just hoping that I haven't opened a can of worms with this conversion Head Bang
_________________
Wahl drivers
Back to top
grader
PostPosted: Fri Nov 18, 2011 7:04 am    Post subject: Reply with quote
once the track breaks in it will stretch. 2 inches sag is ok with antiratchets. your main concern will be stud clearance, check it carefully and add to protectors if needeed.
_________________
the early bird gets the worm, but the second mouse gets the cheeze.
Back to top
Grimm
PostPosted: Fri Nov 18, 2011 8:51 am    Post subject: Reply with quote
I think you'll be fine with your track tension...and as said, the track will stretch, more so with the studs. You may find that you'll eventually have to tighten the track after a while.
_________________
2011 Apex Standard
Back to top
Display posts from previous:
Post new topic   Reply to topic    TY 4 Stroke - Totallyamaha Forum Index -> Skis, Studs, Tracks and Aftermarket Suspensions All times are GMT - 6 Hours
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot attach files in this forum
You cannot download files in this forum
Powered by phpBB © 2001, 2005 phpBB Group
TY4Stroke brought to you by Totallyamaha.com
This site is not an official site of Yamaha Motor Corp, USA or any other Yamaha entity.
Opinions/comments expressed on this site are not that of Yamaha or any other Yamaha subsidiary or affiliated company.
