leftdoo
Has anybody put on rail extensions? Im thinking about doing it after my ditch ride today in 2-3 feet of blown in snow. Im use to my 04 doo 136 floating level. Short track nytro feels like Im always clawing my way out. Even blasting onto the top of deeper snow at warp speed doesnt help. Im sure Yamaha will have a 136 or so next year but I was planning on keeping this one a while. Also this is my first ripsaw track. Probably more of a trail performance track??????
Sled Solutions
Ulmer
Tracks USA
I have them on my Nytro.
Go with the Cobra 136 track it hooks!!!
Tracks USA
leftdoo
Will the cobra 136 still be good on the trail?? Did you have to change gearing and or clutching??
Sled Solutions
I will know after this weekend but it's suppose to be the best dual purpose track out right now.
Clutching and gearing will not be known until after I get a few more rides in.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
The clutching will likely require a little adjustment (should be able to adjust via the rivets in the weights). I have complete kits in stock and if you don't like rail extensions I can also get 1 piece billet rails machined as well.
Like Paul said, the Cobra track looks like it will be a great trail/off trail track!
Goddo
I gotta say, the Nytro looks fantastic as a 136...Nice work
phat bstard
Srxspec
Do you feel the extentions will be as strong as the complete rail from Ulmer? If it was having the@#$#$# pounded out of it .
PB
PB
richierich
i offer rail extentions and complete package's.far as strength i have yet to break a rail ext. and i break everything else.not my fault of corse
http://www.richmotorsports.com/store/vi ... OU60VIW199
- Apr 17, 2003
- Menno, SD
- Menno, SD
phat bstard said:Srxspec
PB
Phat bstard, the complete rail is probably slightly stronger, but I have yet to see the rail extension break in the 5+ years they have been around. With it tying into the OEM axle slot as well as the hyfax area they are pretty rugged.
Sled Solutions
Vmax4
- Apr 18, 2003
- Orondo, WA
- 2010 FXNytro MTX 162 SE with a 270 hp MCX Turbo and assorted goodies!
Do they bolt into the rivet holes for the track adjustment bolts? Or do you solid rivet them in?
Thanks,
Steve Burdick
Thanks,
Steve Burdick
Sled Solutions
Vmax4 said:Do they bolt into the rivet holes for the track adjustment bolts? Or do you solid rivet them in?
Thanks,
Steve Burdick
Everything is bolted after you drill out the rivets.
