| View previous topic :: View next topic |
| Author |
Message |
1000 Bound Veteran
Posted: Thu Aug 14, 2008 7:25 pm Post subject: MSD Launch Master WOW |
Just installed the launch master stutter box. Sled is an Apex with the MCX rear mount at 12 psi. Complete trail sled set up for the asphalt. Sled is to have 260 claimed HP. Sled was terrible launching with turbo lag.
I now have the stutter set at 4900rpm and it builds 4-5 PSI boost.
Can anyone tell me an approx hp the sled would have had at 5000rpm with zero boost and now with 4-5 psi boost at 5000?
The flames coming out of the exhaust pipe are incredible.
Also need to know th adownfall to the stutter and the dangers to the motor.
Thanks |
| Back to top |
1000 Bound Veteran
Posted: Mon Aug 18, 2008 5:55 am Post subject: |
| well had the msd out to test this weekend and it is absolutley the best mod for the buck for drag racing. An honest 3.5 tenths reduction on the asphalt |
| Back to top |
bert Extreme
Posted: Sat Aug 23, 2008 8:23 am Post subject: |
| Is it that would work great on hard pack snow ? |
| Back to top |
TJ YAM Newbie
Posted: Sun Aug 24, 2008 9:39 am Post subject: |
WHAT KIND OF ET, MPH
NOW
BEFORE
HAVE THE SAME SLED AND WAS THINKING OF PUTTING IT ON THE BLACKTOP _________________ OH YEAH OH YEAH |
| Back to top |
hlmrx1 TY 4 Stroke Guru
Posted: Mon Aug 25, 2008 6:57 am Post subject: |
| TJ YAM wrote: | WHAT KIND OF ET, MPH
NOW
BEFORE
HAVE THE SAME SLED AND WAS THINKING OF PUTTING IT ON THE BLACKTOP |
Sounds interesting, I'd like to know those details too. Guys fill out your profiles so we know where you're from etc. _________________ 2003 RX1 Turbo sold, replacement is here!!!
2004 AM Snow Open Mod Shootout Bracket Champ!
My drinking team has a racing problem!!!!
9.7521 1/4 @ 133.37 mph @ 10lbs.
9.5899 1/4 @ 135.54 mph @ 12lbs.
Best MPH in the 1/4 Mile 137.13mph. or 220.69kph. |
| Back to top |
1000 Bound Veteran
Posted: Mon Aug 25, 2008 8:02 am Post subject: |
| Sled was running with me on it at 250lbs with gear at 6.5s 1/8 and now 6.22. All in hte 60ft. went from 1.62s to 1.23 60fts. With a driver 50lbs lighter the sled was running 6.3 prior so we hope to see it in the 5s in the 1/8. With the lighter driver it ran 9.91 at 143 mph in the 1/4 prior to the msd |
| Back to top |
Otis RX Expert
Joined: 09 Sep 2003 Posts: 389 Location: Otis Reservoir Otis, Mass.
| Back to top |
FLYBYU VIP Member
Joined: 24 Nov 2003 Posts: 922 Location: south elgin, il
Posted: Tue Aug 26, 2008 9:20 pm Post subject: |
| it's simply just plug and play. there's room by the hi/lo light switch for the button. get one from radio shack. I have mine set to 5300 rpm stutter. to much for snow. I use mine for grass drags with a speed track running chisels. Just trying to keep the front end down now. Wish i would of extended the rails. Just going to run the illinois races this year, moneys tight. |
| Back to top |
1000 Bound Veteran
Posted: Wed Aug 27, 2008 7:50 am Post subject: |
| Otis RX wrote: | How was the install?
I'd like that for the ice. Rear Bender w/ 2560r
Unbelieveable how hard it hits on ice! |
On an RX1 I would be surprised if it took any more than 5 minutes.
The Apex takes longer cause you need your 5 year son to reach in with his hands to connect the harness. |
| Back to top |
TBird Expert
Joined: 25 Dec 2004 Posts: 208 Location: North of Sweden
| Back to top |
RX1DERFULL Extreme
Joined: 04 Jun 2007 Posts: 119 Location: Summerside , PEI
Posted: Wed Aug 27, 2008 11:34 am Post subject: |
The launch mater will not work with 03 RX-1 CDI ignition.
This was confirmmed with msd tech support. |
| Back to top |
FLYBYU VIP Member
Posted: Wed Aug 27, 2008 11:41 am Post subject: |
| It will only work with coil on plug applications. yes the apex is harder, even more when you have a mid-mount turbo (cpr). |
| Back to top |
rxrider Moderator
Joined: 25 Apr 2003 Posts: 5758 Location: Lakselv, Norway - 70N & 25E
Posted: Wed Aug 27, 2008 6:00 pm Post subject: |
The RX-1 has coil on plugs! Can it be used on the RXs? If not, why not? _________________ :-)
rxrider's Turbo Garage - http://www.ty4stroke.com/viewtopic.php?t=47473
2003 RX-1 ER - Custom front mount turbo, Water/Alcohol injection, Fox Floats up front, ZX-2 144" in the rear.
2008 Apex RTX - Bone stock.
Wearing a TekVest when riding. |
| Back to top |
FLYBYU VIP Member
Posted: Wed Aug 27, 2008 6:24 pm Post subject: |
| rxrider wrote: | | The RX-1 has coil on plugs! Can it be used on the RXs? If not, why not? |
The launch mater will not work with 03 RX-1 CDI ignition. |
| Back to top |
zross1 Expert
Posted: Wed Aug 27, 2008 7:28 pm Post subject: |
| How does the msd know when to actually launch and stop the studder? Is it with the break? |
| Back to top |
