TY 4 Stroke - Totallyamaha Forum Index
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
MemberlistPosting Rules  MemberlistTY Chat SearchYamaha Parts FinderMemberlistOn-Line Store MemberlistVIP
Log in to check your private messagesActive Topic (24h)  (12h)  Log in to check your private messagesMapMemberlistTY.NET Classifieds Log in to check your private messagesTY Webmail
 MemberlistTY Tech
MemberlistTY Home
MemberlistTY Forum
MemberlistATV Forum
Just changed the Oil
Goto page 1, 2, 3, 4  Next
Post new topic   Reply to topic    TY 4 Stroke - Totallyamaha Forum Index -> FX Nytro General Talk
View previous topic :: View next topic
Author Message
2008 Nytro RTX
PostPosted: Tue Oct 07, 2008 11:31 am    Post subject: Just changed the Oil Reply with quote
On my sled,Pretty painless. I used 0w-40. It says to use 3.17 since I didn't change the oil Filter and I just used 3 and the oil light is not coming on I ran it for about 10 mins.(Let it Idle),Should it be ok or should I add more? How I did it was I used the drain plug on the bottom of where you check it then I filled it up where the dip stick goes,That is how you should do it right?
_________________
2015 Viper Rtx LE blue and white ( Snow checked )
2010 skidoo 600 RS
2008 Nytro rtx blue and white snow checked
2002 Viper 700 triple
2000 arcticcat 440 snopro
Back to top
View user's profile Send private message AIM Address
unpride
PostPosted: Tue Oct 07, 2008 11:53 am    Post subject: Reply with quote
There's 2 drain plugs. Why would you change the oil and not change the filter? You put all the time in and just did a 1/3 of the job. A filter change is the most important thing in the first 500 miles. You probablly have to much oil in it now. Id start over or take it someplace to get it done right
_________________
2008 RTX
192 studs w/ double backers Stud Boy
9" sharpers Stud Boy
Skinz Super-Q
white float plate
Fox Float guards
Ulmer Stage II
Muffinworks Float Resi's
Muffinworks 4" riser
CR10EK's
6200 miles and she is still limpin along
Back to top
LJ 452
PostPosted: Tue Oct 07, 2008 12:36 pm    Post subject: Reply with quote
Wow!
Unfortunatly, you've only done about a third, but on the bright side you'll be even better at it this time.
1.) Drain the Oil Resivor (Can on the side of the sled).
2.) Drain the Crank Case (There is socket head cap on the bottom of the motor. You'll have to remove belly pan, and flimsy gaurd covering the bottom of the engine.
3.) Remove and replace the oil filter (on the Apex I could see why some didn't want to do it, on the Nytro it's right there when you remove the pan. There's just no reason not to change it.) The first time it's tight!
4.) Carefully remove the gold color elbow fitting from the bottom of the oil can. There's a screen that should be cleaned. I would do this after break in and then at least once every two years. I do it every time. Carefull not to loose the rubber O-ring in your drain pan. Clean/Reinstall
5.) Clean everything up, install new oil filter (remember to put oil on the O-ring before installing. You can precharge the filter if you like. Up to you.
6.) Replace drain bolts in both engine and oild can. Pour required amount into oil can. At least 3 quarts.
7.) You can pour the recomended amount in the top of the motor, some do, some don't. Again your choice.
8.) Start the sled, make sure you feel the oil can getting warm. Once the oil is warm, check the level, start it up again, wait, check the level. I repeat this until I have reached the desired level, and there is no change for two cycles. FYI, slightly below is better than slightly above.
9.) Put all the covers back on, pat yourself on the back and have a beer.
10.) ride the sled and enjoy not having to buy oil at the gas stations.
I think that about covers it, if I forgot anything I'm sure someone will chime in. The Nytro really is easy to do the full service. Phazer and Apex, not so much.
_________________
2011 Sno Pro 720
09' Nytro RTX S.E. w/ 128" Hacksaw, Replaced with above.
08' Phazer MTX
Back to top
skyboz
PostPosted: Tue Oct 07, 2008 12:40 pm    Post subject: Reply with quote
^^^^^WHAT HE SAID^^^^^
_________________
You can outrun the gun, but you can't outrun the bullet!!
Back to top
2008 Nytro RTX
PostPosted: Tue Oct 07, 2008 1:06 pm    Post subject: Reply with quote
So what I did is no good your saying? Yamaha does no recommand changing the oil filter 1st oil change so I did not. Since I didnt drain it from the 2nd plug is it going to really make that much of a difference? Or can I just leave it as in and change everything over wen I change the oil again?
_________________
2010 skidoo 600 RS
Back to top
2008 Nytro RTX
PostPosted: Tue Oct 07, 2008 1:08 pm    Post subject: Reply with quote
And when you check the oil do you screw the dip stick in or no?
_________________
2010 skidoo 600 RS
Back to top
NLVMAX
PostPosted: Tue Oct 07, 2008 1:50 pm    Post subject: OIL CHANGE Reply with quote
Start completely over and do what LJ 452 said. He has detailed info for first timers on an oil change.
Very important to change oil filter and let all all oil drip out of drain holes. And yes make sure dip stick is completely in when checking oil level but as LJ 452 said do not screw in.
Good luck this time around. Thumbs Up
_________________
http://www.ty4stroke.com/viewtopic.php?t=62124
09 Nytro SE
700 TRIPLE TRIPLE
04 GRIZZLY 660
Back to top
LJ 452
PostPosted: Tue Oct 07, 2008 1:58 pm    Post subject: Re: OIL CHANGE Reply with quote
Very important to change oil filter and let all all oil drip out of drain holes. And yes make sure dip stick is completely in when checking oil level.
Do "NOT" screw in the dip stick, it's on page 49 of your owners manual. Also page 41 tells you that the oil filter "SHOULD" be changed after 800km or 500 miles.
_________________
2011 Sno Pro 720
08' Phazer MTX
Back to top
NLVMAX
PostPosted: Tue Oct 07, 2008 2:06 pm    Post subject: Reply with quote
Agree on that! Do not screw in dip stick Yamaha Rule
_________________
09 Nytro SE
700 TRIPLE TRIPLE
04 GRIZZLY 660
Back to top
LJ 452
PostPosted: Tue Oct 07, 2008 3:18 pm    Post subject: Reply with quote
Since I'm sure you are or have changed out the chaincase fluid as well. that level should be measured with the dip stick pushed in. And if using Amsoil Series 2000 I can atest that filling it between std. and the rev. line seems to work fine. I would however split the case open to wipe out any residue which there will be a fair amount of unless you changed it before. The chains and gears break-in as well and a lot of metal filings re produced. If you don't want to split the case I would change it again after you've ridden it to warm up the oil and mix it around. Since so little chain cse oil is used changing it often isn't expensive, with no filter to clean it it seems to me like a cheap insurance for chain cases. After all a blown chaincase is has the same result as a blown motor, you don't move.
_________________
2011 Sno Pro 720
08' Phazer MTX
Back to top
clicker_clit
PostPosted: Tue Oct 07, 2008 3:28 pm    Post subject: Reply with quote
Don't worry about it how you did it. As long as you have enough oil it will be fine. I have seen people change the oil and not change the filter. I did however change my filter but I never bother with the bottom plug because it is nothing more than a pain in the ass. Yamaha should place the filter on the side of the motor like most engines. It is nice to know that your not suppose to have the dip stick in when checking levels. I ended up using three quarts as well and it was showing in the middle of the dip stick. I then added some more oil and ended up being over and I had to drain it back out. Another way to get all of the oil out is to start the sled when you have the filter off. I have seen this technique as well. The last option is to not change the oil at all. The motors are pretty durable and I know people that have never had any problems. You'll wear out the frame of the sled long before you ever have any motor problems no matter what you do for maintenance on a four stroke. I had to change my gearing back so I changed my chain case oil once again. I ran out of the yamaha oil so I just used standard valvoline 90 weight oil to get the proper levels recommended. This will be my last change using yamaha oil products. It is much cheaper to use napa or alternative products. I new this buying the yamaha brand and walked out of the store kicking myself.
_________________
Yamaha. It's simple. A better valued snowmobile for a better person!
2008 FX Nytro RTX w/Reverse.
Back to top
View user's profile Send private message MSN Messenger
2008 Nytro RTX
PostPosted: Tue Oct 07, 2008 3:54 pm    Post subject: Reply with quote
So I don't know what to do,Some other people say its fine as is and others say its not fine. I might very well just do it over again and change the filter
_________________
2010 skidoo 600 RS
Back to top
no4smoke
PostPosted: Tue Oct 07, 2008 4:48 pm    Post subject: Reply with quote
Your sled you decide!, or leave it up to a vote. My vote is for a redo, drop the oil and change the filter.
Back to top
towerrigger
PostPosted: Tue Oct 07, 2008 5:49 pm    Post subject: Reply with quote
You haven't gotten the used oil that was sitting in the bottom of your oil pan on the engine. Redo that oil change and read through the manual fully or use LJ 452 write up. Take that unit to the dealer if your unsure. Some dealers say that it could void your warranty if it isn't brought in for the first service.
_________________
2010 Nytro MTX SE 162 boosted
Back to top
2008 Nytro RTX
PostPosted: Tue Oct 07, 2008 6:09 pm    Post subject: Reply with quote
Well I know how to do it (Now) Would I be able to use the new oil I just put in or should I just use all new oil?
_________________
2010 skidoo 600 RS
Back to top
Display posts from previous:
Post new topic   Reply to topic    TY 4 Stroke - Totallyamaha Forum Index -> FX Nytro General Talk All times are GMT - 6 Hours
Page 1 of 4
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot attach files in this forum
You cannot download files in this forum
Powered by phpBB © 2001, 2005 phpBB Group
TY4Stroke brought to you by Totallyamaha.com
This site is not an official site of Yamaha Motor Corp, USA or any other Yamaha entity.
Opinions/comments expressed on this site are not that of Yamaha or any other Yamaha subsidiary or affiliated company.
