adirondac blue
I am looking at a 08 nytro, what should I look for. How does the front end look if tweeked. Anything else to look for.
Nitrousman1
The shock won't look centered in the A-Arm if the front-end is tweaked. Take a tape measure and check the spindel distance on both sides from a fixed spot on the tunnel.
arteeex
To clarify the post above; there is some variation from sled-to-sled with respect to where the shocks sit relative to the upper a-arms. However, the spacing on both sides of an individual sled should be the same - or very close. I wouldn't worry about a 1/4" difference, but you don't want to see either shock in contact with an upper a-arm.
Also, check that the ski tips are even when they're pointing straight ahead. The handle bars should be square to the chassis too.
If you can see a plate (with a round hole in it) welded to the frame just below where the lower a-arms mount, the sled as an '09 sub-frame on it now. That's probably a good thing.
Bad Attitude
- Nov 21, 2005
- People's Republic of NY
- 2014 Yamaha Viper LTX SE
08 Nyto
Hey Blue,
I got an 08. Very low miles, First oil change To busy with work to ride my sled. Need to sell getting new XTX.
Hey Blue,
turbie583
- Apr 18, 2007
- CNY
- 2008 Yamaha Nitro
check front bushings
2008 Nytro RTX
A gym so you can get strong and hold on to it!
FJR1300
I HAVE A 2008 NYTRO RTX WITH 4000 MILES EXCELLANT CONDITION
$ 7800.00
NOTHING WRONG WITH IT
$ 7800.00
SledderSteve
- Apr 23, 2003
- Orange County California
- Rental
Back on topic, check out the FAQ: http://www.ty4stroke.com/viewtopic.php?t=58910
