RxThunder
I have a 2006 Apex GT with 1400 miles on it, just purchased at the end of last year. I have only ran it through the backyard on minimal snow once, Impressive is all I can say. I love it. The one thing I noticed is that when I squeeze the brake normal the light comes on like it should, but if I squeeze harder the light goes back out to just the running light. Anyone have this issue or have any ideas of what it could be? I was thinking maybe a bad switch? Everything else works like it should.
That would be a switch issue
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
If the switch is anything like the Phazer's, you can take it apart, clean the contacts inside, add a bit of dielectric grease and it should be good to go. My '09 had a similar issue.
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
My 07 GT had the same issue. It was still under warranty so I had it replaced. But I researched here and found the same solution that moosman suggested.
Good luck!
Good luck!
polarisconvert
- Mar 22, 2006
- Corunna, MI
- 2005 Yamaha RX1
Ted Jennety Clutching, jetting, air box mod.
Arctic Cat Z1 Turbo 128" Rear Suspension
128" Hacksaw 1" track.
Heated seat
Might try adjusting the switch at the lever.
RxThunder
Sounds like I need to check that switch out, that's what I figured it was. Just wanted to see if anyone had similar issues. The sled is currently in another state where I store it for summer, I can't wait to get it ready for winter. Already have had a few nights of snow up here! thanks for the tips!
Murse
- Sep 7, 2012
- Cornwall, Ontario, Canada
- 2011 Yamaha Apex Std Red
Had same issue I found a used brake switch on ebay from a wrecked Apex even on another model like RTX which is where I got mine from they are the same switch. For 10 dollars I replaced the whole thing. Easy to do. Bam problem solved switched it out.
