nherbst454
If we're still N/A would we be able to run the separator return line directly into the Mag Cover where the turbo drain goes? I ask because it appears there is already a tapped hole behind the plug in the center that we could thread a barbed fitting into. Does anyone know the thread dimensions?
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
2016 Vector LE For my Bride
2007 Phazer GT, 136" Stretch.
2002 SXR600 (still own)
1997 SX600 (sold)
1997 XT500 (sold)
2013 Can-Am Maverick 1000XRS
This is what the MPI kit does.If we're still N/A would we be able to run the separator return line directly into the Mag Cover where the turbo drain goes? I ask because it appears there is already a tapped hole behind the plug in the center that we could thread a barbed fitting into. Does anyone know the thread dimensions?
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
Both holes in the mag cover are a weird thread size for those OEM plastic caps. I think you would have a hard time trying to find something that fits correctly. The MPI kit is cheap and the adapter MPI machined is perfect fit and the kit is cheap. This kit also come with the plug for capping off the old return line on bottom of the oil tank. MPI part number hsk-1160 .
stingray719
MPI found some problems using a regular banjo fitting with flow and I understand that having done oil coolers in race cars. Big flow difference in a 90 degree banjo fitting and an angled connector.
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
1997 SX600 (sold)
1997 XT500 (sold)
I talked to MPI today for a bit about this, and they are looking into a kit for NA sleds that like to get sideways. Normally NA sleds don't have the same problem as the turbos because they don't create pressures like the turbos do. Turbos are much worse at pucking oil into the intake than NA sleds.
MPI did confirm that all the kits now come with the Seperator return mod, and those installed through Yamaha have this plumbing arrangement.
Martens199
- Oct 1, 2012
- Saskatchewan, Canada
- 2008 Yamaha nytro 153 mcx190
2015 SRViper mtx se 162 mcx270
I would also like to know how to make this work with a MCX turbo kit. Because the turbo return line feeds into the small hole on the mag cover as well. Would be nice to know if guy could use a tee or y fitting to return both into the one hole, and whether or not that will cause flow problems.
trevorl1
- Mar 14, 2015
- Nova Scotia
- 2014 sr viper xtx-se
What would be the difference from the new tank/baffle upgrade to a roll over valve. Sometimes when we're in a pinch we will roll our sleds right over to get them unstuck. I did it once with my factory xtx before reading on here, I want my sled to be able to do it with no worries this year.
The rollover valve is like a door it closes off the escape of oil. The baffles and box are just like a maze. They are hoping by making the oil snake around that it wont escape but it does. Rollover valve works but you must use the tether and now with the new flash it requires alot of patience to get the system to reset. But it definitly works and no need to carry oil. Saved my butt last year in dark in middle of a whiteout middle of nowhere!
Looking at the new YZF. Look how they did this one:
Martens199
- Oct 1, 2012
Just opening this back up... I did install a mcx oil separator update to drain to the mag cover. But I'm still having problems with losing oil pressure while on steep climbs and or walking with the skis up. It's better but not fixed. Has there been any new news on this issue?
yamahaguy
Ride SAFE
- Apr 20, 2014
Just curious if you're running the new or old style oil tank?
Martens199
- Oct 1, 2012
It's a 15. It has the dipstick so I assumed it's has the baffle and screen.
iola
- Sep 24, 2015
- Kimmirut
- Sr viper stx 2015
mine is 15 no dipstick
yamahaguy
Ride SAFE
- Apr 20, 2014
You have a early build 15 then. Production changed some time mid summer to the dip stick tank.
